al lkosmal's Avatar
75S engine rebuild
I'm rebuilding a 75S, 2.7 engine.........This is a stock rebuild (it happens). This will be the full meal deal......Thursdays progress......
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 04-03-2020, 01:28 PM
al lkosmal's Avatar
the seamy underbelly
wow...this one is a mess.....lots of leaks with JB weld used as a seam sealer.....original smog pump manifold and injectors.....this should be a total beeyatch to get apart...however, due to the oil, the exhaust came off without a struggle....this one is definitely due for a rebuild.....behold
regards,
al
RGruppe #669
Old 04-06-2020, 05:11 PM
Is this one staying CIS? Or are you working some induction magic on this one too?
Old 04-06-2020, 05:56 PM
al lkosmal's Avatar
No, unfortunately no EFI magic on this one....a stock rebuild....and it needs it.......but I have two other engines underway....a 2.7RS-ish and a 3.2....those two will have to satisfy my EFI obsession.....
RGruppe #669
Old 04-06-2020, 06:01 PM
al lkosmal's Avatar
messy
Wow....this is a messy one.....however, the oil inside the engine is very clean.....I think that this one leaked so much, it got a constant supply of fresh oil...rockers and cams look great. One head nut was off and the rest of them were so loose, I could just about loosen them with my finger tips....I thought that maybe it was the result of the head-studs pulling a bit.... and it might be....but all cam housing and the case perimeter nuts were also very loose....in fact....almost every fastener, with the exception of the cam nuts and rocker nuts...were not tightened near to spec........it has made taken this one apart pretty easy, to date...although there is one nut, covered with JB weld that might be on pretty tight...... behold the filthy beast....
RGruppe #669
Old 04-10-2020, 06:52 PM
I like the orange silicone on the intakes.
Old 04-11-2020, 07:00 AM
al lkosmal's Avatar
oh yes....lots of nice sealing attempts on this one....silicone, JB Weld,, copper sealant spray......all the good stuff.
RGruppe #669
Old 04-11-2020, 09:44 AM
Al, do you do your own machine work? Will you be installing case savers etc, yourself?
Hoping you document what work is carried out on the case.
Old 04-11-2020, 02:02 PM
al lkosmal's Avatar
Nope...heads out to Craig Garrett, case out to Ollie's
RGruppe #669
Old 04-11-2020, 02:16 PM
al lkosmal's Avatar
innie
Crank looks good.....main bearings are slightly worn....overall, internals are not too shabby.....
RGruppe #669
Old 04-11-2020, 05:56 PM
al lkosmal's Avatar
head studs
As I was disassembling the engine, the head stud nuts were so loose, I could almost turn them by hand. It took almost no force at all to remove them.......and here is why.
regards,
al
RGruppe #669
Old 04-17-2020, 09:12 AM
Been working on these cars since 1971. The beauty of those internals still amazes me.
Old 04-17-2020, 09:55 AM
al lkosmal's Avatar
tasty
Even the stock 2.7 CIS pistons and cylinders look tasty, right out of the box......
regards,
al
RGruppe #669
Old 05-14-2020, 11:55 AM
Is that a 5 cylinder engine?
Old 05-14-2020, 01:33 PM
regards,
al
Well, after 45 yrs, was the heli-coil/threaded insert/case saver/time cert head stud fix debate settled? Or is that like the dreaded dilivar / Supertec debate?
Reparations for neanderthals!
'70 914-6, 1965 Mustang GT - RIP, '74 911, '01 Box S
'12 Ducati 848 Evo - RIP, '16 Yamaha R1, '13 Aprilia RSV-R
Old 05-14-2020, 01:51 PM
al lkosmal's Avatar
Yes, we're doing everything we can to reduce weight.........
RGruppe #669
Old 05-14-2020, 03:22 PM
al lkosmal's Avatar
No, the debates continue...we'll need another 30-40 insert threads (no pun intended) to ensure that we gather every opinion out there. It would be interesting to hear what type of oil everyone recommends though...............
regards,
al
RGruppe #669
Old 05-14-2020, 03:26 PM
al lkosmal's Avatar
shiny heads
The heads for the 75S are looking a lot better now that Craig Garrett (CGarr) has worked them over...........
if you need your heads rebuilt...he is the man.
RGruppe #669
Old 05-14-2020, 04:29 PM
something to be said about stock Al, im in the process of a one off resto now on a rare 911, and really digging the whole restoration thing. Our of my norm, hot rodding, but its fun
Old 05-14-2020, 05:05 PM
911, 914-6, 928
Took my heads out to Craig Garrett last week, he's conveniently 1-1/2 hours away so I took the drive in person. He said about 2 weeks...
Old 05-14-2020, 06:49 PM
