Designer King
Pls Confirm Where to Pry Apart 14 Pin Connector
I've read about people breaking brittle plastic and losing pins so I want to get this right. Do I merely pry apart the 14 pin connector along the line between the red and yellow arrows? Note: pic is not from my car.
Thanks.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Been here a while
Yup, it truly is that simple....I don’t see much risk of breaking anything unless you try to pry the red side or the yellow side without trying to separate it from both sides somewhat evenly.....I’ve never even thought about a risk of breaking it, it’s pretty tough....they’ve all come apart easily for me.
looking for 1972 911t motor XR584, S/N 6121622 |
Designer King
Thanks blucille.
that's where it separates.
it should come unconnected pretty easily. the "cap" on the right side of your pic can come off is you need to do some rewiring inside it.
If caps come off connectors, individual connector pins will try to come out.
Be prepared Been there, done that
1980 911 - Metzger 3.6L 2016 Cayman S |
Designer King
Thanks Ty and Ted.
Yes, I need to replace a broken yellow wire to the TTS. It broke just outside the connector housing.
cycling has-been
Anything plastic, or a plastic derivative seems to deteriorate by just my looking at it. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
