Bilstien inserts for boge struts
I have just removed the struts from my 85 targa which has had Bilstien (green) inserts installed by a PO. When I removed the dust cover there were no rubber bump stops as shown in bentleys. Is this normal for the bilstien inserts.
Old 07-11-2020, 12:41 AM
I have a similar setup one one car. It does have the bump stops.
When you think about it. It should have those rubber bump stops.
Old 07-11-2020, 02:55 AM
Under the radar
Trackrash's Avatar
Don't the bump stops go on the bottom on Bilsteins?
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-11-2020, 11:43 AM
No snubber on those.
206 637 4071
Old 07-11-2020, 12:08 PM
Walt Fricke's Avatar
Yeah, the bump stops are "on the bottom" where you can't see them in the Bilstein for Boge, same as on the Bilstein for Bilstein. Inside, so to speak, as that is where the moving shock parts are - like Trashrack's picture.
Old 07-11-2020, 08:39 PM
Thanks for that it makes sense.
Old 07-12-2020, 11:57 PM
A small correction. If you remove a Bilstein shock from a Bilstein strut, you can then see the bump rubbers, as the first picture showed. I don't think there is a practical way of opening up a Bilstein for Boge shock (John's picture)to see what is in there or to change it. But there are bump rubbers there - have to be.
Maybe it is easier than I think to open up that Boge package and reseal it, but I don't think so, at least not unless you are in the shock repair business.
Hard to get any manual right about everything. For years Clymer's (US publisher of manuals about all sorts of vehicles)had a whopper or two, misleading generations of backyard mechanics. With the fora we have these days, information is much easier to get.
Old 07-15-2020, 08:18 PM
Targa_PB_78_SC
mike sampsel's Avatar
Ditto on mine, no rubber on my bilstien inserts for boge struts.
I will be checking my torque settings once my tool arrives. Took things apart today to determine if I need rubber on top.
Thanks to JW, I'm sure I do not need any rubber bumpers. Have to use my full weight to compress the dang things!
BareRearedRookie
Old 02-21-2023, 01:33 PM
Ditto here, I just replaced the original Boge inserts with Bilstien B8s and there's no rubber anything below the insert.
Old 02-22-2023, 07:35 PM
The bump rubber is internal to your style of shock , First pic
is normal BIL, second yellow shock or green , has the internal bump rubber
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 02-22-2023, 08:23 PM
