Harpo's Avatar
Front 964 caliper mod
Can some one please measure the height of a caliper that has been modified for use on a S/C type strut. I need to know how much of the ears to machine off.
I borrowed this photo from pu911 who just sold the set up that I'm trying to create
Old 08-16-2020, 04:07 PM
Harpo's Avatar
Beggars can't be choosy but in a perfect world some one has a pair that were just "professionally" machined and they have access to a surface plate and a height gauge. Could I also get the drill and tap depth please?
Old 08-16-2020, 04:10 PM
Bill Verburg's Avatar
You don't need that, just machine square and then the caliper adapter makes up the rest
Bill Verburg
Old 08-16-2020, 05:36 PM
Harpo's Avatar
So I simply remove enough of the ears to create a flat spot big enough for the adapter bracket to sit on?
Old 08-17-2020, 04:44 AM
Harpo's Avatar
Is this the correct part number 930 351 047 00? This looks like a floating rotor design. I don't believe that I need or want floating rotors
Old 08-18-2020, 05:04 AM
930 351 047 00 is a floating left front 32x304mm 930 rotor
You can use it or a same size non floating rotor, w/ either you need a flat hat, if you want floating you need all the other parts for the '78 rotor
note that the 930s went to a 1 piece design w/ integral hat in '80, this rotor cannot be used w/o 930 fenders and hubs
floating
non
Bill Verburg
Old 08-18-2020, 01:03 PM
