'73 911 T Targa
Ever heard of Stablbus?
I’m looking at an oil drain valve to make oil changes easier on my wife’s daily driver.
I like the design of the one made by Stahlbus between that Fumoto since the Stahlbus has a couple of fail-safe features.
Has anyone heard of Stahlbus? It’s made in Germany so it’s got to be good, right?
https://www.ecstuning.com/b-stahlbus--parts/stahlbus-oil-drain-valve-set-m14x15x12mm/sb-210211-s-na~s/?gclid=EAIaIQobChMI3dLr887x5QIVFIiGCh2MGAdhEAQYAiA BEgJLafD_BwE
Old 11-17-2019, 08:01 AM
speednme1's Avatar
My coworker just bought one. It looks very well made. Should make oil changes easier.
Rey....77 930 "the Mistress"
Old 11-17-2019, 08:39 AM
High Life's Avatar
IMHO - I love my Fumoto.. you should not have any issues..
No problems since I installed 2 years ago and the safety catch on it is solid..
1981 911SC
Old 11-17-2019, 03:47 PM
Discseven's Avatar
Quick... Stahlbus is a clean design... obviously moreso than a Fumoto. If there's a downside to Stahlbus, it's that it requires it's own drain plug to push the ball in. Then that "extra part" must be cared for / not lost. Fumoto down side... it was initially introduced with no security to prevent the valve from opening. Company has since introduced a plastic lock. That lock might work well. I prefer using a clamp on the valve to prevent the switch/tab from going anywhere. To remove/install a clamp takes seconds. Some consider Fumoto a "slow" drain. That's subjective. Surly it's possible to do other things during a drain. I thought about swapping my Fumoto out for a Stahlbus and decided against it---only because of the special drain plug needed.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 08-07-2020, 09:01 AM
For my once-a-year change, I'm totally ok with removing a bolt instead of introducing a possible failure point. I've seen too many of those doo-dads fail on AX cars and take motors with them.
Matt - 84 Carrera
Old 08-07-2020, 09:11 AM
BER BER is offline
BER's Avatar
Porsche Crest
+1 for Fumoto. I have one installed on my oil tank; it is two years old and works great. Very secure locking mechanism and never leaked a drop. Kept the drain plug on the engine block.
Bruce
'12 Carrera S DFI
'84 911 Carrera
Old 08-07-2020, 10:16 AM
Also +1 on Fumoto. The locking mechanism won't accidentally unlock, it takes
deliberate pressure to move it.
These units are used on million dollar earth moving machines and over the road trucks. I'm sure if they were marginal units they wouldn't be used in those applications.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 08-07-2020, 10:43 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Quick drains have been used on piston engine aircraft for decades. With 100 hour oil changes, and some at 50 hours the possibility of a stripped drain hole is very real.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-07-2020, 02:05 PM
I use the Fumoto on my 968 and my 911.
It's a high end product and well worth it. Even if you only change the oil once a year you will love this valve when you have too much oil in the tank and want to take a little bit out!
Old 08-10-2020, 08:45 AM
Fumoto...I've used them on my SC and Carrera for over a dozen years now.
Very happy with them...no problems at all.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 08-10-2020, 09:04 AM
I use the Fumoto mostly to make oil changes a LOT less messy. I shove a rubber hose on the valve, open the drain and drain the oil directly into my 5 gallon container. Zero splash and mess. Then I remove the oil filter. I found Pelican sells this handy tray.
It keeps the oil from the filter from making a mess down the side of the engine bay and covering the wires. This photo was right after I did a pulley seal replacement. One step is to move the AC compressor over and my compressor wire is on top of that tray and not next to it like it should be. That has been fixed.
So say the Fumoto valve is slow. I don't have an issue whit that at all.
Old 08-10-2020, 10:19 AM
