What is correct fan color
I’m working on my 69 E barn find. I’m leaving it completely original. It has great patina I do not want to lose. The engine is out and being rebuilt along with tranny. I hate putting the engine back in with the cooling fan not being painted though. We all know how they look with age. So this piece I would like to paint. What brand paint or color code is correct for this? I think a very patina’d car can have this one item looking fresh??
Old 03-17-2019, 09:30 AM
proporsche's Avatar
originally there was never any paint....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-17-2019, 09:32 AM
cycling has-been
bkreigsr's Avatar
Do a Pelican advanced search.
Someone here has duplicated the coating process the factory used back in the day. - couple of years back -
Bill K
Old 03-17-2019, 12:02 PM
Hilbilly Deluxe
emcon5's Avatar
The correct color is a slightly corroded magnesium.
82 911SC Coupe
GTI Cup #43
Old 03-17-2019, 02:27 PM
+1
Fan center removed and plated, fan left alone, squirted with Gibbs, or clear cerakote.
Old 03-17-2019, 04:07 PM
Senior Advisor
James Brown's Avatar
powder coat pink and piss everyone off!!
08 Cayenne Turbo
Old 03-17-2019, 08:53 PM
This.
If you have a show car that you take to car shows, paint it whatever color you like. 99.9% of the general population will think it looks better painted and never realize that Porsche left the magnesium unpainted from the factory. If you are a serious concours guy, don't paint it, as it is not correct and will take points off your score if it is painted.
Most any "paint" will chip off on the leading edges of the fan if you drive your car like they are designed. That paint will end up as chips on top of the cooling fins, causing issues with cooling.
Some modern coatings will last longer, but I can't imagine much of anything will look good after 50,000 miles. The factory original corroded magnesium is not pretty, but it is 100% functional and does not chip off into the cooling fins. My car is closing in on 170,000 miles and the fan is not pretty but sure will not chip off the coating.
In the end, it is your car, paint the fan if you want. It does look better for a while.
Old 03-18-2019, 08:01 AM
Under the radar
Trackrash's Avatar
Originally Posted by Dpmulvan View Post
+1
Agree, except, cleaning the mag fan material is a PIA, but worth the effort. The trick is once in a while wipe it with Gibbs to keep the corrosion off. Any coating will chip and look like crap after a while if you drive it much.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-18-2019, 09:47 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
paint
[img]
Here is what I used.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-18-2019, 09:50 AM
Here is what they should look like although with magnesium, and different weather conditions they vary.
If you keep it oiled it stays like this:
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 03-18-2019, 10:56 AM
cycling has-been
bkreigsr's Avatar
Original fan paint/surface treatment
Old 03-18-2019, 11:22 AM
What would you use to clean it to get to the appearance you have with yours? Mineral spirits and a scotchbrite pad?
Old 03-18-2019, 01:20 PM
Under the radar
Trackrash's Avatar
I used diluted ospho with a scotch-brite pad then with 0000 steel wool wet with Gibbs. If your fan is really bad, you may have to start with 240 sandpaper.
Gordon
Old 03-18-2019, 01:26 PM
Thanks, that helps!! Man your fan looks good!!
Old 03-18-2019, 03:43 PM
Shaun @ Tru6's Avatar
A 69 fan and housing should look like this one in a 73 RS I did a year ago. Owner of the car who was selling them when they were new said it's as close to original finish as he's seen. I developed my own prep routine and chemistry to surface the pieces after being disappointed with Dow 7 and other finishes. It's basically a blotchy dull grey.
Tru6 Restoration & Design
Old 03-18-2019, 04:17 PM
pwd72s's Avatar
Fan untouched...around 50,000 on the car at the photo time.
Old 03-18-2019, 04:31 PM
needspeed's Avatar
Here's another pic from a recent engine rebuild:
Old 03-18-2019, 04:45 PM
Diss Member
Quicksilver's Avatar
Winning!
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-18-2019, 08:27 PM
piscator's Avatar
Beadblasted and then brushed on some Gibbs oil finsh.
Robert
Old 03-19-2019, 05:17 AM
I used a parts cleaner, bushes / pads and a little elbow grease. I wanted to clean the fan, but not destroy the hard earned patina. You can't get that back.
Matt - 84 Carrera
Old 03-19-2019, 05:34 AM
