nene's Avatar
Axle Joint - imminent Failure? (86 Carrera)
I purchased a cv joint kit (here) to replace a pitted joint and to my surprise, the material
has me concerned, or should I be?
After cleaning the rust and smoothing it down with a Scotch-bright pad, the surface is smooth, but I can still feel the roughness with my fingers. Should I replace it or is this even a concern?
BTW, the brand is Lobro.
For comparison, the first one is the original that was on the car.
Serge
Old 08-09-2020, 09:46 PM
Once packed with balls and grease, just drive it.
The failure noise is the ball wearing into the trough front to rear, not left to right.
On reassembly, if it goes together too easily, assembly is incorrect.
Bruce
Old 08-10-2020, 05:34 AM
nene's Avatar
Thanks Bruce,
I am finding that it is a very tight fit when putting all the components together.
Serge
Old 08-10-2020, 08:17 AM
When they're tight like that it's because you put them together backwards. Easy to do. Easy to correct.
1973 911T Sepia Brown MFI
1986 Carrera Meteor Gray Metallic
Old 08-10-2020, 08:25 AM
nene's Avatar
Steve,
I have tried both ways and indeed one way is much easier and more flexibility. I have seen several videos on this and sorta confused on which way is the correct.
Old 08-10-2020, 08:33 AM
Assembled, they need to move in and out as the trailing arms move up and down
If they don’t move in and out you’re tying your suspension up and wind up destroying the bearing cage.
Bruce,
Old 08-10-2020, 08:40 AM
assambly
On the area between where the balls pivot is a flange.On the inner race where the balls pivot there is a flange When assembling align the narrow portion of the inner to the wider portion of the outer then install.It is stiff when new like Rawknees until it gets worked in.Ciao
Old 08-10-2020, 09:08 AM
Show a picture of your assembled joint straight face on and I can tell you whether it's right or wrong in 3 seconds.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-10-2020, 09:52 AM
nene's Avatar
Ok,
I can assemble the old setup in 5 minutes and when I attempt to do the new one, it is tight as hell and almost impossible to get the 5th ball in. I do recall that when I received the joint in one piece, it was tight as well.
Pic #1 is the old setup
Old 08-10-2020, 10:18 AM
AutoBahned
RWebb's Avatar
Bruce
Agree. I -have- seen VW people polish the damn things but they are crazy...
re: last pics see the "Reconstructing" thread for some info
Old 08-10-2020, 11:42 AM
nene's Avatar
Thanks RWebb, I did go through that bible! Lot's of info.
In regards to my last pic, do you see something that sticks out?
Serg
Old 08-10-2020, 11:52 AM
AutoBahned
RWebb's Avatar
I'd just try to re-assemble them and see where it is binding.
Old 08-10-2020, 12:48 PM
pete3799's Avatar
The CV's in your pictures are assembled correctly. Small face of the inner race mates to the large face of the outer.
Pete
79 911SC RoW
Old 08-10-2020, 01:01 PM
nene's Avatar
Thanks everyone for pitching in, I am going to grease it up a bit and massage it to
loosen the tolerances.
Old 08-10-2020, 02:34 PM
Walt Fricke's Avatar
The unworn parts of the grooves of used CVs from 25-30 years ago seem to have had a much smoother finish. And the joints had some kind of black finish, which I suppose hid the color changes from the surface hardening. But these new ones seem to work OK, though I don't recall getting ones which looked as ugly as these.
Old 08-10-2020, 07:32 PM
Assembled correctly. You just need grease in it.
Old 08-11-2020, 03:16 AM
nene's Avatar
Greased, closed up and ready to be part of the car again!!! It's been 3 weeks of NOT driving
it, so it needs some revvvving!
I can't wait until I attempt to put all of 340lbs of torque on the hub nut!
Serge
Old 08-11-2020, 07:20 AM
The last set of lobro cv joints I got a year ago were rough finished like that, I greased them and installed they are ok so far.
Old 08-11-2020, 02:39 PM
