7783911's Avatar
need help identifying this part
Post heater backdate and engine bay clean up, i saw this and dug around the PETS but cant figure out what it is
83 SC engine (in 77 Targa)
thanks
bob
Old 08-19-2020, 10:11 AM
There was a hose connection on some SCs
Tony was looking for the keeper recently
Bruce
Old 08-19-2020, 10:14 AM
Hose connection for the carbon canister.
Old 08-19-2020, 10:33 AM
7783911's Avatar
I figured it was a hose connection :-)
but no idea what it served (purpose), obviously its not in use on my SC engine..i had guessed maybe it had to do with a temperature switch of some kind since it was open to the external top side of the engine? Nothing a breather would require...just run out of ideas what it could be
HELP!
Old 08-19-2020, 10:43 AM
7783911's Avatar
Gomer
Really...wow, thats wasnt on my guess list..so whats underneath that tube, ie what does it connects to?
thanks!
Old 08-19-2020, 10:45 AM
You connect that nipple with a hose that fits and run it to the carbon canister nipple. It moves air through the canister.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjEzsOz6afrAhUCZc0KHRvqAuYQrAIoAXoECAIQA g&url=http%3A%2F%2Fforums.pelicanparts.com%2Fporsche-911-technical-forum%2F632552-carbon-canister-connection.html&usg=AOvVaw3Lc9iCSCTVNlnKFOjvE1mr
Old 08-19-2020, 10:48 AM
There's positive air pressure inside the cowl that the cooling fan creates. That pressure purges the CC from gas fumes.
Old 08-19-2020, 10:51 AM
7783911's Avatar
found this and now it makes sense
Here is the key:
1. Expansion chamber
2. Vent chamber
3. Charcoal canister
4. Engine fan shroud (under air cleaner)
5. Hose from fan to charcoal canister
6. Purge line from charcoal canister to air cleaner
so it would make sense to cap this off so hot air isnt blowing into the engine bay?
It's not there on a 85 it's in the engine compartment Attached to the package shelf.
Old 08-19-2020, 10:52 AM
7783911's Avatar
mines an 83 so checking now in the pet, but do i cap or just leave open?
Old 08-19-2020, 10:59 AM
I would hook it up.
Old 08-19-2020, 11:03 AM
7783911's Avatar
hook it up to what, there is no remaining Carbon Canister?
Old 08-19-2020, 11:11 AM
Registered Minimalist
75 911s's Avatar
I just plugged mine with a small piece of the hose and a screw and two hose clamps
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 08-19-2020, 11:29 AM
proporsche's Avatar
778..put a cap over it and forget it..no need to have it.Or send it to Tony as Bruce said he was looking for one;-)))
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 08-19-2020, 11:46 AM
7783911's Avatar
Which Tony? If i can get it off easily I will...
Old 08-19-2020, 12:53 PM
proporsche's Avatar
well , you would have to remove the alternator and pull the little lip tube in plus the sunshine clip is a PITA to remove..Just cover it wit a plug.Tony is a 911 engine master ,CIS and WUR ..engine rebuild class is one of his threads...boyt911sc..
Ivan
Old 08-19-2020, 01:13 PM
7783911's Avatar
Ahhhhhh...i dont think i will go that far, i just capped it off and will use some red touch up paint to "clean" it up. Sorry Tony
thanks everyone..PP forums are great!
Old 08-19-2020, 03:06 PM
