Location: Seale, Alabama (25 miles south of Auburn, Al.)
painted alternator fan
I remember seeing Pic's of a red (painted or powder coated )alternator fan. I am having a 3.0 rebuilt and I ask my wrench if he could powder coat the fan, he sent it out to two different companies. They both said they were having problems with the process. Can you paint or powder coat these fans or do you have to purchase them all ready painted? And if so who sells them?
Thanks Rick 1977 911s 3.0 |
Powdercoat, zero maintenance, or polish, fair amount of maintenance. Have it bead blaster first. Also. do a search. There are TONS of pictures and posts on this topic.
JG
1985.5 944 GTS |
Most any powder coater can do that for you, but beadblast is critical
Bob |
nice doggie
It needs to be real clean or the powdercoat process will bring out any oil or grime in the pores of the metal. Also you will want to mask or grind the ends of the blades to aviod problems with fit upon reinstall.
Jerry 78 SC hotrod 02 Mini Cooper S |
Powder Coating Fan
I had my fan and circular mount coated, and the retainer band
and pulley polished. Here's how it looked off the car... And in the car.... There have been loads of pics here of fans of many colors... do a search and see if it gives you any ideas...
Impotence...Nature's way of saying "No hard feelings." McDaniel 1974 911 Targa 1995 Toyota Avalon 2004 Toyota Tundra Extended Cab |
It'll be legen-waitforit
Since no one else metioned it here, if you are going with powder coating the fan MUST be clean and it has to be outgasses prior to coating. This usually involves heating the fan in the powder coating oven for a few hours first.
Cheers
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Al Reed can polish, paint and powdercoat the fan, housing or strap. His work is impeccable.
1984 Targa |
Senior Member
After bead blasting, the fan should be placed in the PC oven for a few DAYS, to outgas. It is probably the outgassing (bubbles) that are giving the coaters fits. The fan is magnesium. With a file, you can trim the outer edges of the blades to avoid interference with the fan housing. After coating, I mean. But I would be sure to tape any spots you don't want coated. We taped the yellow metal area (pulley area) on mine but did not tape the back. So, the coating spewed through the vent holes. Finally, you DON'T want to get coating on the inside of the hole that the alternator shaft goes into. That hole is fairly precision, and coating would mess it up.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Al Read did powder coated my fan, valve covers and engine tin. He also did a pretty good job polishing/powder coating the fan housing.
