Harpo's Avatar
Help with tire recommendations 6 & 7 x16
I'm switching to 16 inch fuchs and I'm struggling with tire sizing. I'm looking for a summer performance tire. I also don't want to screw up the accuracy of my speedo so I was hoping for a 185 but that is proving to be a problem. I have always liked the appearance of the Toyo proxies and the Yokohama Neova ADO8R but that forces me in to a 205/50 R16 for the front and 225/50 R16 for the rear.
Old 08-27-2020, 04:58 PM
What sizes do u currently run?
Old 08-27-2020, 05:51 PM
Harpo's Avatar
OE from the factory was 185/?? R15, however most recently I had 205/60 R15
Old 08-27-2020, 06:09 PM
asking about the height/aspect ration/"???" as that's necessary to determine stock diameter and recommend an equivalent diameter size in a 16" (which is key to speedo consistency)
Old 08-27-2020, 06:15 PM
Harpo's Avatar
What size tires/brand is everyone else using and how inaccurate is their speedo?
Old 08-28-2020, 04:01 AM
racer's Avatar
OEM sizes for a 911 (sc, carrera) for those wheels was 205/55-16 and 225/50-16. Lots of choices available at tirerack for instance.
Brands, compounds (sticky? all seasons?) would really depend on your use and propensity to thrash the car. Sticky is fun.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 08-28-2020, 04:51 AM
Harpo -- speedo is calibrated to the outer diameter of your tire (wheel diameter + actual tire height) -- believe that different factory tire/wheel options had different tire diameters and therefore had different speedometer calibrations - hence my question of what tires/wheels you're currently running (and/or the sticker in your engine bay specifies)
My '86 targa was delivered with (and I still use) 205/55-16 up front and 225/50-16 in the rear (speedo reads rear wheel rotation) -- my speedometer is (and has always been for me) around 5 miles per hour optimistic, which I understand is pretty normal -- see https://www.theglobeandmail.com/globe-drive/culture/commuting/why-you-may-not-be-driving-as-fast-as-you-think/article11487709/
A 225/50-16 tire has an approximate diameter of 24.86 inches
See you're in MI -- keep in mind that summer tires generally behave quite poorly (get very stiff/lose traction) when outside temps get into the 40s (f) and that track-centric streetable tires (e.g. Yoko AO52) can actually be damaged if STORED in such temperatures.
Old 08-28-2020, 06:53 AM
Harpo's Avatar
Because I have headers I have no heat. I have no plans to ever drive in 40 degree temperature so I'm leaning towards a sticky tire
Old 08-28-2020, 07:46 AM
1979 911 SC
I went with the Michelin Pilot AS4 for my 79' SC. 205/55 R16 in the front and 225/50 R16 in the back. Down here in SW Florida the rain can come out of nowhere so I sacrificed extra sticky summer performance tires and instead went with the all season tires. I'll never see snow but rain is definite! I won't be picking up the car until next week so I can't comment on how they feel yet but I know those summer performance tires are absolutely terrible in the rain.
Old 08-28-2020, 07:56 AM
The Firestone Indy 500 comes in original sizing, it's a Bridgestone in Firestone branding.
205/55/16; 225/50/16
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 08-28-2020, 08:07 AM
Pedro '84 Coupe's Avatar
I'm happy with the Bridgestone Potenza RE71R on mine. Good sticky performance tire. I got caught in the rain once in them and it wasn't too bad, I just took it slow in the corners. I don't have many miles on them but they are almost 6 years old so will likely be replaced later this year. They are good tires, but I'm leaning toward either Michelin Pilots or Continental ExtremeContact for the next set.
2000 Boxster S and 2016 Audi A6
Old 08-28-2020, 08:09 AM
I'm running Direzza ZIII for both street and track use on the same size wheels. I'm happy with them.
I've run them as cold as right above freezing.
Old 08-28-2020, 08:33 AM
