Indicator stalk not smooth
The indicator stalk of my just purchased 86 works fine, putting it into left or right position feels fine too, but when then manually putting it back into neutral it feels as if I have to 'force' something beyond what I would expect. It just does not feel right (or is this 'normal' German grundlichkeit?)t. It does work fine though. Has anyone a picture of the open mechanics that go with the indicator? I am tempted to open it myself . I know it's assembled with rivets, and I realise it's a potential can of worms to get it back together. But before doing so and investing all the time, I want to understand how the mechanisme works and looks like.
Old 09-04-2020, 04:47 AM
sugarwood's Avatar
I installed a brand new stalk in my car. When pushing it back into neutral, it does take a bit more force than you'd expect. More than a modern stalk.
Yours is probably fine. Before messing with stuff, I would find another local 911 and try their stalk. Best to focus on the next issue, not this one.
1986 Bosch Icon Wipers coupe.
Old 09-04-2020, 05:56 AM
mine is like that too. Im not sure if its hurting anything. Just make sure your steering wheel is centered with the canceler so you can avoid manually canceling it as much as possible
Old 09-04-2020, 06:01 AM
That was something I noticed when I bought my 86 Targa a few years ago. The indicator stalk just doesn’t have the nice feel when cancelling signaling that my 90 964 does. But, it’s a small complaint, and the signal lights all work properly, so I don’t even think about it any more.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 09-04-2020, 06:37 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
For a company that's supposed to get the weight and feel just right, they really blew this one. Operation of the blinker stalk is splinters-under-the-fingernails annoyance. I don't understand how they could have made it this unpleasantly.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 09-04-2020, 07:34 AM
thanks guys, very helpful feedback
Old 09-04-2020, 01:16 PM
New-ish 911SC Targa Owner
pampadori's Avatar
Yep, they're all like that. Feels broken and you replace it and the new one feels exactly the same.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 09-04-2020, 03:18 PM
famoroso's Avatar
I was hitting some of the switch's electrical contacts with Deoxit D5 spray and accidentally sprayed a pretty big shot of it into the plastic mechanism (Deoxit came dripping out from the bottom of the housing) and it served to inadvertently lube things up. It didn't fix the issue, but it did improve the manual cancellation operation / feel somewhat. I don't think this off-label use should cause any problems. So far, so good, but I still avoid manually cancelling the turn signal as much as possible.
I'm a big fan of Breakfree CLP spray lubricant, but I hesitate to use it in this application for fear of damaging the plastic components. The stuff is pretty amazing though. I'm tempted to try it as I know it would considerably improve the switch feel. I have an old, "graunchy," switch on the shelf, perhaps I'll try the Breakfree on that.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 09-05-2020, 05:37 AM
to those interested, I modified the stalk mechanisme and now it's smooth as butter. Read here in a separate thread a smooth switching indicator stalk, finally
Old 10-02-2020, 09:33 AM
7783911's Avatar
alex..nice write up
Old 10-02-2020, 11:02 AM
