ZAMIRZ's Avatar
Driver's side window problem>>>
Okay, so a few weeks ago the driver's side power window decides to take its merry time going down, I thought nothing of it and it rolled back up just fine. Well, a couple days ago I'm driving around and hit the switch to roll it down and it drops 1/4 inch and then doesn't move....
Today I took the door panel off to see if I could find anything that might be stuck against it, making it sluggish/not move at all and everything looked fine visually. Any ideas on what else I should check?
Amir
'83 911SC
Old 04-20-2003, 01:54 PM
RazorRacer's Avatar
Try replacing the window switch. An easy way to test is to use the passanger switch on the drivers side. These switches fail so quickly.
Stopped racing and became a drummer
Old 04-20-2003, 02:24 PM
ZAMIRZ's Avatar
RazorRacer,
thanks a lot, that was exactly the problem. I switched it to see if it made a difference and now the window comes down and goes back up nicely. I cleaned the connections on the bad one with some denatured alcohol and put it back and now both work fine. This forum kicks ass.
later,
amir
Amir
'83 911SC
Old 04-20-2003, 03:17 PM
RazorRacer's Avatar
Amir,
How cool. I actually got to help someone. Usually someone is helping me on this board. Glad it worked.
BTW, the 911SC is soooo fine.
Craig
Old 04-20-2003, 08:28 PM
