Loose nut under engine...?
Had a quick check under my -74 today and noticed a 13mm nut that was somewhat loose. It is on the left side of the crankcase. Nut sure what is the purpose of this one is, so I need help on this one.
Anyone ?
Old 09-09-2020, 07:53 AM
El Duderino
tirwin's Avatar
Pic didn't work.
Also, I was expecting a selfie. I always say the biggest problem with my car is the loose nut behind the steering wheel!
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 09-09-2020, 07:55 AM
Ye right ))
Old 09-09-2020, 07:58 AM
Registered Minimalist
75 911s's Avatar
It's a through bolt. It starts leaking then someone 20 years ago over tightened it and pulled it.
You can remove it and put a bolt in as a temporary fix until you split the case and address the pulled threads.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 09-09-2020, 08:10 AM
Old 09-09-2020, 08:14 AM
Had the same problem I removed mine tapped it and put a 10mm bolt in.....
Old 09-09-2020, 10:36 AM
Vintage Owner
Jack Stands's Avatar
Luckily it goes into a blind cavity so you can tap it for a bolt until the case needs to be split. It’s for the intermediate shaft webbing and not too critical.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 09-09-2020, 06:16 PM
