Acceptable voltage range 3.2
Hi all,
I spent the weekend ripping around in my '85 Carrera and have a few questions for the more experienced owners on here. On a few occasions, when I blipped the throttle to downshift, I heard a loud shriek from one of the belts. It does not occur EACH time I rev-match, and I cannot replicate it when the car is actually in gear. I picked up this voltage meter/battery monitor a while back and popped it in as an afterthought as I was on my way back through town. The reading would swing as I applied or backed off the throttle but I'm worried about acceptable readings? At times the meter read as high as 18v and other times it dropped below 12v. Is it dangerous to have the voltage spike so high? The fan belt doens't look worn or frayed, and there isn't a worrying amount of slack, but it seems likely that these two things are related. I have the original tool roll including the fan pulley holder tool. It would also be helpful to understand what range is considered "safe" for the electrical system. Thanks in advance. |
How long was it at 18V? I've seen mine touch 15 before, but it's nearly always around 14. Does your battery show any damage such as leaking acid? Keep a good eye on things.... you may need a new voltage regulator.
I'd check volts at the battery using a multimeter as those cigar lighter units can be a bit wonky.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow ![]() |
18 volts is (imo) too high to drive until fixed -- check under/around battery for evidence of boiling over and have alternator/voltage regulator rebuilt -- should be an old-school shop in/around Portlandia
you could confirm it's not the gauge by testing it in another (newer) car Last edited by darrin; 10-04-2020 at 03:46 PM.. |
Driver
I wouldn't feel comfortable with the car voltage spiking to 18 v either. Spikes are better than sustained and/or frequently elevated voltage. But I 'd always be worried that I could fry something.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Voltage regulator
Looks like a voltage regelator issue.
Have the the VR tested under load. Should be around 14.2V Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Caveman Hammer Mechanic
Stop, do not start or drive, there are sensitive capacitors in different components and they are rated at 16v. At 18v stuff starts to sizzle along with the battery. Replace/rebuild the alternator. Stat!
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
This. Have a local shop rebuild it, and be sure they put in new bearings. You will have a perfectly working alternator for another 100,000 miles and it will 100% be the right wiring and easy to reinstall.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
From what I understand, best course of action for the alternator is to remove it and bring it to a shop that specializes in alternator repair/rebuilds. It would be great to find someone who's worked on Porsche units previously but the consensus seems to be it's not a must-have. I'd be grateful for recommendations in the Portland/Vancouver WA area if anyone has recent experience. Is the voltage regulator considered part of the alternator rebuild or is that something I'd need to replace separately? I'm unsure if the voltage regulator is something that could get repaired/rebuilt at an alternator shop. |
I believe that most if not all 3.2s came with an alternator and internal voltage regulator.
Get yourself voltage regulator..once you are at it have a look at the rotor where the brushes ride..If still ok just replace it and you`ll be ok
or take a picture of the rotor and show it to us here... Ivan
1985 911 with original 501 761 miles...807 506 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 10-05-2020 at 01:28 PM.. |
Under the radar
Yes. Since '82
I replaced my alt with a modern alternator from Classic Retrofits: https://www.classicretrofit.com/collections/upgraded-alternators I also added a Clewett pulley system: Clewett Alternator/Crank pulleys The 911 series alternator is the same basic design from the 60-70s. The Classic Retrofit brings a modern design to the table, check out the sites/threads. Having a modern alternator and pulley system brings my 911 solidly into the 1990s. Was it cheap, nope, but when compared to the high amp alternators for race trucks and sports cars, the price was in line with low production volume custom parts, same with the pulley system, its a beautiful piece of CNC machine work and is worthy of being buried on the back of a 911. BTW my alternator runs amazingly consistent 13.9-14.1 temperature dependent. Check the voltage at an RPM above idle, say 1500 RPM. The Classic Retrofit puts out a whopping 175a at rated RPM, while my amp schedule will never get anywhere near that, having a system the for all intents and purposes is constantly "idling" along at any possible load.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 10-09-2020 at 04:47 PM.. |
Must mean 13.9 - 14.1....
I've been though this with several 80's 911s. Don't bother with just the voltage regulator, replace or have a quality rebuild of the alternator ASAP. As mentioned above, many components are at risk. I've ruined batteries, clocks and a tach due to voltage spikes.
1989 Carrera Former flings... 2009 Carrera S (x2), 1986 Carrera, 1997 993, 1983 911SC, 1995 993, 1987 Carrera, 1985 Carrera |
The high voltage reading on my 1980 SC is about 13.8 volts. With the engine/ignition off, the battery reads 12.5 volts. I get essentially the same numbers on my 1994 Jaguar XJS so they appear to be in the realm of normal! The high voltage reading on my 2014 Ford F150 is usually 14.2 volts.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Analog Air Cooled
I am always looking at my voltage. 14.2-13.9 normally with nothing on. I had it go to 15.1 once and my radio was tripping out. Turned out to be some old grounds. Check door light contacts. Also check off your battery too.
86 Targa 91 964 13 6 SPD Cayenne |
Mine is between 13.8-14.2.
ken 87 targa |
1986 Coupe here...Going through all things electrical and here is where I am:
Battery Cold: 12.7 Car started at idle: 14.1 - 14.0 Car at 2000 rpm: 14.3 Car at 2000 rpm w/lights: 13.9 Just took the car out for an hour and voltmeter in dash read 14.0 pretty much steady with lights on. With the lights off meter read 14.3 while driving. This car has over 200,000 miles on it and comes from a humid background (if that matters). 14 and above seems high to me...just not finding a definitive answer. I have no issue with pulling the alternator and rebuilding - it is very old and very used. Hopefully resurrecting a thread from 2020 isn't too taboo here ![]() Thanks! Erik
1986 911 Coupe 1986 911 Targa |
I don’t remember the factory spec, but 14 doesn’t seem outrageous. The risk would be any spikes as the electronics in these cars are old and not very robust. If concerned, I would check your grounds and have a quality rebuild done on the alternator… or replacement, but I think that is big bucks now.
Analog Air Cooled
After all grounds changed and new VR, 13.8-14.5 nothing on. Above 2000, 14.3-4 for the most part. Only counts over 2000rpm. Load up the fogs and ac at night and idle is 11.9-12.0 until 2000. Book says same.
Thread Tools | |
Rate This Thread | |
