Warm Up Regulator failure symptoms
I am having some problems with my 83' SC. In speaking with my mechanic he said that a faulty warm up regulator could be the culprit.
In your experience, what are some symptoms of a failing or faulty warm up regulator?
Old 10-11-2020, 02:37 PM
Crotchety Old Bastard
RarlyL8's Avatar
Most common symptom of an aged unit is cold start issues. Fuel pressure will not drop as low as it needs to causing a leaner than spec mixture. The engine put-put-puts to life. Problem only gets worse with time. There can also be chop throttle and idle issues along with warm running issues however that is less common. What issues are you having?
Old 10-12-2020, 05:00 AM
T77911S's Avatar
I would delete this thread or the other one, or others and only talk about your problem in one post.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-12-2020, 05:31 AM
Three (3) topics......
This guy has one for the WUR, CDI, and FP. Not sure what was his problem/s with his car. That would be another topic.
Tony
Old 10-12-2020, 12:20 PM
I have an intermittent complete loss of power. I press on the accelerator and the car feels like it is going to die. I will downshift and I have power again. I might drive the car for a minute or two (or 10 seconds) and will seem fine and then it will happen again. Total loss of power. Along with this the car will backfire. This has happened twice now. After the first episode I replaced the fuel filter. I took it on a short drive just to run a quick errand after I replaced the fuel filter and the car was fine. About a week later I took it on a longer spirited drive (getting it up to temperature) and about 10 miles from my house the same thing happened only worse this time. Not only did I have complete loss of power multiple times trying to "nurse" the car home, but it backfired more than the first time and the car actually died twice......Sound familiar to anyone?
Old 10-12-2020, 03:53 PM
RarlyL8's Avatar
Sounds ignition related, not something the WUR would typically cause. I'd start with the CDI box then coil then green wire. Assumption is this only happens when the engine is warm yes?
Old 10-13-2020, 05:13 AM
My guess is green wire problem. Backfire suggests unburnt fuel in the exhaust which will happen on ignition failure. Green wire can short to outer sheath.
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 10-13-2020, 07:02 AM
Yes, that is correct. It only seems to fail when it is up to temperature and I have been driving the car for 20-30 minutes
Old 10-13-2020, 07:44 AM
Zaz Zaz is offline
I had this happen a few years ago and it was the CDI failing.
74 911 Coupe
74 Triumph TR6
97 Jaguar XJ6
Old 10-13-2020, 08:47 AM
Walt Fricke's Avatar
Old mechanic's rule of thumb: start your hunt for a fault with ignition.
Old 10-13-2020, 09:41 AM
Impossible to diagnose without at the very least a video. First thing you need to do is check fuel pressures. Then share the results both cold and warm.
You would be better off taking it to a mechanic.
Old 10-13-2020, 10:24 AM
The relay under the seat, when bad, acts like a faulty WUR.
The fix is minimal and available at the local auto store.
Once replaced, if it works, you win. If not you didn’t bite the bullet for a replacement WUR that still doesn’t work.
Another thought is track your Llambda From the battery through the system
Bruce
Old 10-13-2020, 11:43 AM
Mechanic’s advises.....
His mechanic suspected that the car could have a bad WUR, CDI, FP, etc. the way the car was behaving. And that’s the reason the OP is searching all the symptoms he could collect over the Internet. Instead of diagnosing and testing what is wrong with his car, he is collecting all known symptoms people had with their cars. What a way to solve his problem.
Tony
Old 10-13-2020, 12:22 PM
theiceman's Avatar
Tony
Sherlock Holmes he aint ..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 10-13-2020, 12:30 PM
T77911S's Avatar
coil or CD
start with coil
tony,
problem is he has several threads. that does not work well
i think I would find a new mechanic
RACE CAR:: sold
Old 10-13-2020, 04:21 PM
