915 Tweaking Question - Bit of a grind
So...I think some of you know my recent updates, but if not here:
-New clutch cable
-Newly adjusted said cable
-New brass everything in the pedal box
-New brass spacers in the shift linkage
So now as I shift 1-2 and then 2-3 and 3-4 I am getting just the hint of a grind...very brief...but something that wasn't there before. Shifting is good...just this 1/4 second grind/bite.
Is this the link/shifter or the cable adjustment? Got any ideas? Many thanks in advance.
Current:
1984 911 Targa Whale Tail "Gemma"
2014 Boxster S (wife) "Sir Jenson" (She named it...not me)
Previous GF's - 986 Boxster S, 987 B Cayman, 981 B Cayman, 981 GT4
Old 10-24-2020, 08:24 PM
Bill Douglas's Avatar
Originally Posted by JohnTucker View Post
-New clutch cable
New Swepco in the gearbox?
Old 10-24-2020, 09:10 PM
Racer
winders's Avatar
Either you are shifting too fast or your clutch is misadjusted....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 10-24-2020, 09:25 PM
walt's Avatar
Did you recheck your initial adjustments. Is your clutch pedal about the same height as your brake and is the clutch engaging at about 1/3 pedal travel.
Walt
82SC 3.0
81SC 3.6
Old 10-25-2020, 04:30 AM
The PO put Kendall in it Summer of 2019.
Current:
Old 10-25-2020, 06:39 PM
That all sounds right. I'll double check tomorrow. Thanks.
JMT
Current:
Old 10-25-2020, 06:40 PM
Flojo's Avatar
your brass bushings don't provide any play in the linkage anymore, so your alignment must be adjusted VERY precise.
and even then it's no help.
the more stiff/solid the linking is, the more downside it brings regarding good adjustment results and changes of shift feel when cold/hot.
I'd remove the brass bushings and swap for poly bushings and improve your hand-shifting according to the shift pattern.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 10-26-2020, 04:30 AM
