Engine drop - Removing driver side line and elct. conct. ?
1. I'm trying to get this electrical connector off and it is being a PITA. I have not put a tool to it on because I'm afraid to break it.. any tricks to get it off?
![]() 2. I guess this other line is a fuel line and it has two connectors.. I haven't really tried to take it off yet because the fittings are unlike the other fuel lines. Any suggestions on it? What side should I pull off to drop then engine? Any risk of stripping them n stuff... ![]()
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
The short hose is NLA so don’t bend it too much
Try the connector closer to the motor The lambda electrical connection, just pull straight up. Small flat screwdriver might help but recall the fixture is near 40 years brittle. Don’t forget the ground wire forward right side of the trans at the torque tube Undo the ground at battery Remove the starter heavy black wire Bruce |
Engine drop prep........
Tom,
There are two (2) metal fuel lines at the driver side at engine bay. One goes to fuel accumulator and that is the main delivery line. The other one goes to the T-fitting shown in your picture. That is the return. In picture #1, the rectangular plastic connector is the 12-pin plug for the lambda circuit. This is a two-piece assembly, top and bottom section. Grab the upper section and wiggle it up to separate it from the bottom section. The bottom section is mounted on a metal bracket. These are the following things you need to do before you start removing the 2 transmission mount bolts and 2 engine mount bolts:
If you are doing this for the first time, it would be prudent to have a second person to assist you or at least be around. Stay safe. Tony |
Very nice checklist, Tony.... I assume it's for a 3.2 removal?
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
![]() That a LOT of pictures, more than you will think you ever need of each step. The routing of the wires and fuel lines is sometimes difficult to remember, but Porsche routed them that way for a reason.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
The end of the fuel line away from the engine is a bit easier to get at. 11mm open end wrench and a 17mm open end. The 11mm seems hard to get all the way on sometimes. I have one I relieved slightly for an easier fit.
I ended up getting a 17mm crow foot line wrench on a long extension to get the fuel lines apart. There is little room to work in there and I have large hands.
The fuel line is a little tough.... 17mm and 11mm as prescribed
![]() ![]() I wound up replacing it...
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) |
Thank you! My goal is to replace all of the fuel lines while I have it out. That electrical connector proved to be a nightmare. It was stuck on there like you wouldn't believe. One of the bottom edges broke off so it will just barely snap into the metal bracket that holds it. I'm going to try to find a replacement. I think it is a six pin.
![]() In case either of these short fuel lines are ever needed, I can make up both the Feed and the Return with my custom "Direct Connect" fittings... ![]() ![]() All my hoses are E-85 Rated and should last for the lifetime of the vehicle. For info, please email me. Len.Cummings at verizon.net
Len,
Outstanding news. I will be purchasing soon. Are there any other fuel lines you make for the car?
![]() I offer pretty much everything NLA and not available from our host. I started doing this in 1979 after bringing back various tools & fixtures from Cohline in Germany during a Porsche Club Treffen. It's best to email me as pm's cannot carry photos and I depend on them for much of my information. For the SC, in addition to the Fuel Injector Lines with their Silicone Rubber Cover... ![]() I also can Re-Make with new Polyamide tube your original Main Feed and Return Lines that are NLA from Porsche and/or Pelican.... ![]() ![]() Again, best to email me. Len.Cummings at verizon.net
