Replace SSI with Headers for 83 sc
I have SSI in pace but dont use the heat at all...unfortunately even after rebuilding the flappers I still get some heat leak to the floor vent (toasty feet in 90 degree weather). I am considering removing the enter heat system and replacing with headers to the exhaust
what do i need to take into consideration when planning this? is there a risk with the bolts when removing the SSIs I assume headers connect direct to 2 in 1 out muffler? while i need to retune the car as a result of going to headers any other caveats? thanks bob |
it's a plug and play conversion.
maybe block off plates for the heater duct entry ports where the flap regulator sits. and yes maybe a little re-tune. I learned not to heat-tape the headers as you don't want extra heat to crawl back into the engine on a halt.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Thanks Flo
can anyone comment on suggested headers to consider? I m not racing the car, so just functional effective headers (none of that Fabspeed crap) |
I'm good with tools.
I ditched the heat for headers. I certainly don't need heat where I live.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
AG..what make are those?
Those are RarlyL8 Motorsports
bob -- as I understand it, SSI headers are properly sized for a stock(ish) 3.0 (they're a bit small for a 3.2). Thus, not sure what you'd gain, performance-wise, replacing them with a new set of headers that lacks heater boxes.
If the problem you're looking to solve is hot air leaking past the flapper boxes, why not simply disconnect/remove the hoses running from your SSIs to the flapper boxes and leave the SSIs in place? |
Caveman Hammer Mechanic
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Bob - darrin has the same question I have. SSIs are a nice improvement over stock headers. You can fairly easily block off where the flexible hose from the SSIs connects to the air valve part (flappers). To go a bit farther, you could then remove the wires which control the flappers, and seal the opening. A lot simpler and less expensive than going to racing headers. The reasonably priced racing headers are basically like what the SSIs are, just without the surrounding sheet metal to do the heat exchanging. Nobody makes a non-heat exchanger header whose sole difference from stock (or at least the SSI 3 into one configuration) is to get rid of the heat exchanger part. They are all designed to get more performance out of the engine - which isn't needed at all for street driving.
Vintage Owner
Why not simply repair, adjust, or replace the flapper boxes that close off the heater ducts?
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
but yes, somehow the rebuilt went wrong. fix that. Quote:
then rethink the plan
I ve decided to keep the SSIs and fix the flappers..in fact I am not sure where the isssue lies since the flappers appear to be closed but yet I still am getting some heat...i backdated the engine and removed the fan to drive additional blown heat...i will like have to tear into the vent system as well this winter to see if those flaps are working correctly..i dont think they are...should be a lot of fun in an unheated garage!
Those poor flapper boxes lead a very hard life. It's not unusual to get a good deal of leakage past the internal flap when corrosion will no longer allow it to fully close. Fortunately, new ones are relatively cheap, and even available in stainless. From our host, no less. About $140 each for the SSI made ones.
Unfortunately, the bolts holding them on lead an equally hard life. The biggest challenge in replacing the boxes is getting those buggers loose. They are invariably absolutely rusted in place.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
I did pull the flappers, redid them both, ruined one stud while doing, covered in dirty grease...lets just say i did not enjoy the task. New cables and guides done too. Told by experts that just blocking SSI outlets (where flappers fit) is bad idea as SSIs retain heat which heats the engine bay...better off figuring how to block flapper box and let excess heat escape out of open flapper vents. So this winter..I will check flappers again, possibly just replace with new ones to be 100% sure since I dont want to do this job any more times then called for..and then tackle getting all the frunk vents working properly
crap...i am really not looking forward to this without a lift... Might cheat and get my trusted garage to install flappers for me and save all the aggrivation, then tackle the vents |
Since you got the flapper units off once, just take them off again. Make aluminum plates to fit over the holes. If your flapper adventures were like mine, you snapped off at least one of the studs. But two studs/nuts, plus putting caulk under the new plates, will be more than adequate to keep the plates doing their job.
Did you disable the footwell blowers? Easy enough to disconnect their wiring. |
As far as I remember SSI's are really just stainless headers with a heater box surround. Take a close look, they are individual tubes. You are not going to get any noticeable extra power.
Please enlighten me if I am mistaken.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Reiver
SSI's are headers.....
De Oppresso Liber Strength and Honor 5th Legion |
Walt
it was suggested that that block off approach leads to extra heat in the engine bay because the hot air in the SSI collector has no where to go versus when the air is exiting the flapper pr being directed to the cabin. If one were to use a block off plate...it might be an option to put some vents in it (somehow designed to stop water getting in) or leave as is and block at the exit of the flapper (going to cabin) Likely i will bite the bullet and pull them to check integrity of closure seals and just replace them, selling the old one on PP to partially fund (only after I check to see why seal is not working..it was when i rebuilt them). The real issue comes with the ventilation system up front and why air is not following the path it should and whay hot air is getting in if hot air lever is set to closed (or is it always open regardless of slider position..ie should i suspect one of the vent flappers as my culprit?) Porsche got their engines right but lord, the design of that vent system is a nightmare If anyone has an article on re-jigging the vent system I would love a copy (ie..is there one in the porsche service manual since most reference books dont go into much detail on those systems) thanks all |
well, you have to pull the ducting front and rear fron the collector. that's OK,
Thats easy enough but still leaves the SSI outlet open to water/debris which would eventual gunk up the ssi or cause internal damage?
