Confusion With Leak Down Test
I have used my new leak down gauges on a TR3 and now the 911SC. The issue is, I think the gauges are not working. On the 911 test on a few cylinders I hear faint air leaking but the gauge doesn't move? Shouldn't it move even if it is slightly leaking? It is an OTC Tester.
Old 11-08-2020, 07:30 AM
Describe your procedures.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-09-2020, 08:26 AM
I get the subject cylinder to top dead center. Hook the air to the gauges and have the other hose screwed in to the spark plug hole. Gradually increase the air and both gauges go up to about 90. Both gauges stay steady but I can hear air escaping, I think out of the exhaust valve. Not much but enough to hear. Yet the gauge doesn't leak down....
And thanks for responding. I'm puzzled.
Old 11-09-2020, 01:52 PM
Under the radar
Trackrash's Avatar
Switch the two gauges and see if it reads the same.
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-09-2020, 02:01 PM
I haven't used a OTC LD set, but with my set you connect to the air source, zero the second gauge, then connect to your cylinder and note the pressure drop (and listen to where the air is leaking from).
Sounds like your are connecting to the cylinder before zeroing.
1978 SC Targa
Old 11-09-2020, 03:50 PM
I have the same OTC set up. THis is my procedure.
Calibration: Hook up the gauge to the air line, run it up to 100 psi, you will always see a leakage even with the set up NOT connected to any cylinder. My set up is 3% leakage by itself. That number gets substracted from any measurement afterwards. If you see 100 psi on both sides, your set up is bad.
Get the engine cylinder to TDC compression stroke. Screw in the line to the engine plug hole, attach the line to the OTC set up.
Slowly raise the pressure to 100 psi on the input side. The output side will slowly follow but with a minor drop in pressure. Read the difference, compute the leakage percentage, substract the calibrated value.
It is impossible to get both gauges to read exactly the same value. If that happens, toss it, or you have done something wrong.
Old 11-09-2020, 04:15 PM
It is not recommended to use 100psi
The proper in psi is 80 . then do the math from there
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 11-09-2020, 07:12 PM
Ian
The highest I've gone is 90 not 100. Usually I take it to between 80-90 but still the gauge does not leak down even though I hear air escaping.
Old 11-10-2020, 03:36 AM
al lkosmal's Avatar
Why?
Ian
Why is 80 psi recommended? What is the reasoning?
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 11-10-2020, 08:36 AM
VFR750's Avatar
I agree with the question: why not 100psi?
Used 100 psi on mine. Worked fine.
BTW, I took apart my harbor freight version and swapped out a real pressure gauge and closed the orifice down to 0.04”. This is the FAA recommended size for aircooled piston engines leak down testers.
Old 11-10-2020, 11:19 AM
The leak down test was developed by the aviation industry . They set the pressure parameters , if you use more pressure than 80psi you are not being fair to the ring seat on the cylinder walls.
When normal combustion takes place the pressure in the cyl is a rapid expansion of gases . When you inject a constant psi, the rings do not get the benefits of rapid expansion, just a steady pressure downward on the ring , vs the charge getting behind the ring pushing the ring outward and creating a better seal. These are not my words but the words of the Aviation industry, and also what I was taught . The leak down numbers on a nickie Cyl can, and very often are less than one percent , with a proper honing and brake in .
I hope this helps
Ian
Old 11-10-2020, 01:35 PM
VFR750's Avatar
Ok. Aviation settled on 80 psi.
Agreed, can confirm that nicasil with proper honing and broken in rings results in 1% leak down.
Old 11-10-2020, 03:22 PM
This is a link to the tester that I use . Numbers on both gauges, then do the math.
https://www.aircraftspruce.com/catalog/topages/atsdifferentialtesters_orifice.php
I hope this helps
Ian
Old 11-11-2020, 05:14 AM
VFR750's Avatar
https://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99C827DB9BAAC81B86256B4500596C4E?OpenDocument
Chapter 8
80 psi is called out. But oddly they expect someone to find TDC by rotating the propellor against 80 psi.
0.04” orifice for 5” or less diameter pistons. ( that’s us)
Old 11-11-2020, 06:59 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Chapter 8
As an A&P working for a flying club, I did 5-6 differential compression tests a day. Find TDC by screwing the hose into the spark plug hole and rotating the prop, with your finger over the open hole until no more pressure escapes. Hook the gauge set up and add 30-40 psi. Rock the prop back and forth until there is no pressure, on the prop blade, bump up to 80 psi. If pressure is low, allow the pressure to push the prop slightly(counter rotation) and fiddle with the tip to get best reading. This is to get the rings to seat. Valves are not as fussy. This is primarily a diagnostic trend tool, of limited one time use. Rotating a prop with the piston at TDC is easy, get more than a few degrees off TDC and the work load gets heavy quick.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 11-13-2020, 08:27 AM
