Dyno time tomorrow, anyone care to guess what the h.p. numbers will be?
I will be taking blue car tomorrow to get dyno tested and sniff tested to check the mixture.
Here are the particulars of the engine if anyone cares to guess the hp numbers. 3.0 litre, mahle pistons 9.3:1 c.r. Heads mildly ported by Competition Engineering (not race ported) Elgin Mod S cam...supposed to be the same grind as GE60 Weber 40's SSI and factory dual in single out muffler MSD box and blaster coil w/ re-curved distibutor. Any guesses?
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 |
Gawd I love these games! I'm betting, well not betting because bettings illegal,, but I'd say uhmm, 264 rwhp fully corrected for a full moon and light winds from the south.
1991 964 C2 -SOLD - miss it everyday - ![]() 2009 Honda CRV 2007 Audi A4 Quattro - just a sweet personal car - 2000 Land Rover Disco II - lifted 2001 GMC Seirra 1500HD CREWCAB |
225 rwhp.
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
911 user
229.7812 rwhp, with corrections for an overcast sky, east wind blowing & high humidity while using 15.912999900294% to calculate transmission losses.
Where once the giants walked now Mickey Mouse is king. My other car is also a Porsche. |
i agree with fastred....between 220-230 rwhp
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
222.6hp at the hubs (on a Dynapak).
I've got a short stroke 3.2 with more compression, twin plug but only S cams and same exhaust. I took my 245hp (at the hubs), deducted 10hp (for compression, cams, and EFI too - forgot that), then assumed 3 litres instead of 3.164. Me = geeeeeek. WAIT. Revised guess. Deduct another 10hp for wheel dyno not hub dyno. 213rwhp.
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) Last edited by CamB; 07-24-2003 at 04:05 PM.. |
216. That's my final answer
72 911 Although it is done at the moment, it will never be finished. |
210HP
I'd be shocked if it broke 200...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
I would guess 196 at the rear wheels (however I hope that I am wrong, and on the low side).
MBruns for President
194 until you get it tuned - then 208
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Dyno Day postponed, work got in the way. Hopefully I will be on the dyno Mon or Tues. I'll post the results then.
jtkkz is the BIG WINNER.
I would post the graph but I can't open the file ...got a copy on diskette. results are as posted run 1. max power 210.2 max torque 199.1 run 2 max power 210.7 max torque 197.9 run 3 max power 210.1 max torque 195.4 max torque was acheived at approx 4700 rpm max power was acheived at approx 6100 rpm For a refernce point the 993 that was on right before me pulled 240
Are these results at the rear wheels?
Remember that dyno #s are not absolutes. Their true use is only as a comparison on the same dyno under the same conditions.
The comparison of the 3 liter 211# to the 993 3.6 liter 240# is likly valid. It shows that you have a very healthy 3 liter. It would also be useful to take a look at the torque curves, That is where the bigger engines shine. By the way was the 993 a '95 or a vram '96-98?
drag racing the short bus
208 flywheel, or 177 rwp.
The Terror of Tiny Town |
200 HP delivered to the rear wheels at maximum HP point.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
The results posted were at the rear wheels. The test was conducted on a dyno-jet. Factoring a 15% loss through the drivetrain gives about 241 HP at the crank.
Something else to note that was actually commented on by folks at the shop is how much quicker my 3.0 w/ cams/carbs etc. reved up compared to the newer stock cars.
Bill, I don't know what year the 993 was.
Go Speedracer, go!
~240hp out of a 3.0 is pretty impressive! About how much HP gain would you attribute to each of your upgrades? I am assuming about 180hp in stock us spec form.
1981 SC ROW Coupe |
