MSD - setting timing
I have realized hat my digital timing light (Innova) does not play well with MSD ignition. I put in a recurved distributor (no vac advance) and need to set advance to 35 degrees total and 10-12 degrees initial. The problem is that there is no pulley mark for these settings. I know I have to get an analog timing light to cope with MSD but how do I set the initial and full advance with a non adjustable analog light and no pulley markings?
Appreciate the feedback. Thanks |
For a backyard down and dirty you can research or just measure your pulley diameter and then use this online calculator to print out a timing tape that has degree hash marks.
Put a mark at your desired initial and one at your desired total, and have at it with your non adjustable timing light. https://www.blocklayer.com/timing-tape.aspx
Ken 1986 930 2016 R1200RS |
Great idea. Just need to figure out how to do this with engine in car.
Measure the diameter of the pulley
Multiply by pi (3.14 is good enough) cut a strip of paper to that length. 35 degrees is almost 36, which is 1/10 of the strip length. Now you have a strip of paper that will show you where to put a mark on the pully. Put a mark with a silver sharpie. Should reflect more that the base metal. Or file a small notch. |
