Help!!! Stuck on the side of the road
SOS! Was happily driving along music playing when I noticed a horrible noise...starter motor was constantly engaged with the key on or off...I quickly managed to pull over and disconnect the battery...now im stuck on the side of the road. Any suggestions? Thanks! Thinking it’s the starter barrel. Is there a way to isolate the starter motor so I can limp home after a push start?
Old 11-19-2020, 05:16 PM
I would call AAA tow and not chance anymore damage or fire.
Old 11-19-2020, 05:32 PM
They’re on the way...thought I’d trouble shoot if there was a way while I wait the 3 hours for the tow truck!
Old 11-19-2020, 05:34 PM
what year car?
Old 11-19-2020, 06:31 PM
Originally Posted by 76fj55 View Post
what year car?
83 sc.
Old 11-19-2020, 06:32 PM
I assume the starter disengages when the engines running even if it’s turning over? There wasn’t a grinding noise. Just the sound of the starter and vibration through the gearbox.
Old 11-19-2020, 06:34 PM
Under the radar
Trackrash's Avatar
Cam chains grinding?
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-19-2020, 06:37 PM
No engine running fine, just the sound of the starter, engine on or off starter constantly running
1983 Chiffon White 911SC
Old 11-19-2020, 06:38 PM
Still here
pmax's Avatar
I say it's your ignition switch.
Time to tow unless someone knows how to hotwire.
Old 11-19-2020, 06:39 PM
I agree. Ignition switch feels worn. Was hoping there might be a way I can disconnect the starter from the ignition switch and jump start it. But tow trucks only 30 minutes away now...so I’m committed to that.
Old 11-19-2020, 06:42 PM
Originally Posted by 76FJ55 View Post
what year car?
1983 SC
Old 11-19-2020, 06:43 PM
did you have your heat turned on?
No
Then I'm pretty sure it is the ignition switch. in which case you would need to disconnect the yellow wire from the starter.
If you do that, I would make sure the car is in neutral and the parking brake set, before reconnecting the battery. I would then just tap the battery lead to make sure the starter doesn't spin before making the full connection.
Old 11-19-2020, 06:50 PM
Thanks for all the comments, disconnected the starter and all was ok. Jump started and drove home. A new ignition switch will be ordered first thing. Glad to be home!
Old 11-19-2020, 08:22 PM
Glad it worked out and you made it home safely.
Old 11-19-2020, 08:33 PM
Quick question. Is keys reluctance to spring back to on after start a problem with the electrical or mechanical side of the ignition switch?
Old 11-20-2020, 05:48 AM
proporsche's Avatar
Steve, you are ordering only the electrical portion of the ignition switch,correct?
Hello from Carlsbad in Czech Republic;-)the original one...;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-20-2020, 06:34 AM
Ivan
Hi Ivan! I imagine your Carlsbad is a little colder than mine! Ha. So the symptoms were the starter was engaged regardless of key position. This happened out of nowhere, I had been driving all day with no problems. So I’m assuming it’s just the electrical portion of the starter. That said the spring back from start to on feels weak. So I’m wondering is the spring back a part of the electrical switch or the mechanical component of the ignition. Hoping I don’t need to replace the expensive bit!
Old 11-20-2020, 06:38 AM
proporsche's Avatar
yes just get the electrical portion ..It is a little pitta to do but doable;-)there is big load spring in the el.portion ....
Yup you got it ,today only 4 Celsius;-)
Been many times in Carlsbad, on the nice beaches there;-)
Old 11-20-2020, 06:54 AM
