Hanging engine without yoke on HF stand
How many of you don’t bother with the yoke when hanging your engine from the HF stand?
I don’t need to split my case. So I can use all four studs. Got longer 8.8 bolts for the three short ones. Wouldn’t this be better than just the two studs the yoke uses?
1975 911 3.4 outlaw/hotrod? lsd 1988 535i 1987 535is 1973 bronco ranger |
kinda slow
I did it without the yoke, it was fine, but definitely didn’t balance the rotation very well. So it could be a bear to rotate when fully built.
Be careful about damaging the metal outside of the stud where the trans bell housing mates
Bruce |
HF stand works great, just mod the tubes by grinding back a cutout for the case ledge.
![]() close up of tube mod ![]() If I need to split the case I just throw it up on the bench and take off the HF spider. You can also use the HF stand spider to build the half case on the stand like the expensive mount no problem. |
Yikes, don't hang anything with just two studs, it will bend the square tube, break the studs or the case, or all three.
Sent from my Nokia 7.1 using Tapatalk |
I bought a new yoke for about $100 on Samba. It's not as nice as the machined factory tooling but it works fine for weekend warriors.
I’m trying to get that one. I think they are mode to order which requires patience which I have none. But now that I’m hooking this up. I might just wait for the yoke.
You must be referring to my pic. I wasn’t done with the stand. I explained using all four mounting locations.
I cant get this to lineup anyhow. I have the 1 ton stand. Comes with two small and two long arms. The long arms are too long.
Just my 2 cents: I went for the Porsche specific one. About $199 several years ago.
It has the correct cutouts to mount the side with the oil cooler. It is very solid, and will not deflect when a fully built engine is rotated. That last part is non-trivial. That is a wildly expensive case. And the two studs carry all the load via tension. A flexible mount is going to allow the studs to be bent. Bending is bad as the studs can rip out of the housing. Going for the Porsche specific design is a relatively expensive choice. But cheap compared to the engine value. I went with piece of mind. The right tool for the job. Just my thoughts. |
I see the Porsche ones are running $400 these days. Not cheap.
Buy the Porsche yoke and then after you are finished with it, sell it here on Pelican for $100 less than you paid.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Wildman Emeritus
Might cost you a couple of drives to fetch and return it and a case of beer. Still cheaper than the alternatives.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
You don't need the large stand, return it and get the small with the equal length arms. Or drill your longer arms, you already have the pattern.
A few pics on how to set this up for posterity or others if they are interested. spider setup using the four bolt pattern, no balance issues (see how it is centered) ![]() spider set up for one side case building like the special case holder
Thanks.
The larger stand allows me to slide my large HF table jack right up to the mount in between her legs. I need to just wait for the yoke.
Heck, I’m only 5 not 71!
In the late 1990's I used a harbor freight engine stand by modifying the mounting bracket. It worked just fine but I could not rotate the engine 360 degrees with the exhaust system installed.
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
Counterclockwise?
The best part of the OEM one is the groves that match up to the engine.
Much less stress on the bolts.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
In a minimal garage workspace, I once assembled a long block on a HD lazy susan on my workbench. That setup enabled 360 deg. access. Transferred to a dolly platform to attach gearbox and to install. The intake (carbs) and exhaust systems were then installed.
Sherwood |
