Jacking up the front
Ok, I have just jacked up the front and want to make sure that I placed the jack stands correctly. What do you say ?
I placed the jack on the red area with a piece of wood to protect,when i lifted it. I cant see any damage and according to my studies thats the point, correct ?? ![]() Btw, to fix the front is next winter project
I'd move the jack stand forward about 3 inches so it rests on the a-arm cover (tech term). Right now the weight of the car is resting on the a-arm bushing.
Friend of Warren
You need to move it forward and place where I circled in yellow. Right now you have it in a place that could possibly damage the torsion bar or housing.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Ok, will do. Thanks.
Absolutely, positiviely, never place the jack stand where you have the red rectangle. That is merely a belly pan that protects the steering rack - it is not meant to support the weight of the car.
Steve Wilwerding 1998 3.4L Zenith Blue Boxster 2009 Meteor Gray Cayenne |
I have always been told to put the jack stand behiond the front wheel where the three parts of sheet metal join to form the base of the A-pillar. In car later than mine, there is a flat plate welded there by the factory for this purpose. This spot has the advanatge of allowing you to work on the front suspension as well.
Navin Johnson
why the **** do you ask if something you have done is OK after you have done it?
Check this out..... ask the BBS.... use the advice.. then apply...
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
geez, maybe he did it with good intent and just wanted to make absolutely sure. I'd rather have someone ask at any point in time, stupid or not stupid, before or after, rather than have them get hurt or damage their car just because they didn't want to get razzed here.....
Haven't you ever done something, only to second guess your best judgement??
__________________ Clay '80 SC coupe |
Normally i would let this pass, but Tim read my post and you will se "according to my studies". The picture in 101 projects is not 100 %...
Calm down, take a beer and relax... |
Thats where I did it last time. What did I damage? |
I agree - I'd put it on the flat part, in between the two points indicated.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I agree with Randy and Rick, I used that spot and the jack stand cradle fit nicely with the bolts and cover......
Glad I got it right ![]() -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Recreational User
Yup, right between the two bolts....
