brandett's Avatar
Jacking up the front
Ok, I have just jacked up the front and want to make sure that I placed the jack stands correctly. What do you say ?
I placed the jack on the red area with a piece of wood to protect,when i lifted it. I cant see any damage and according to my studies thats the point, correct ??
Btw, to fix the front is next winter project
Itīs my hobby.
911 SC -82 coupe.
My Project
Old 04-25-2003, 09:33 AM
I'd move the jack stand forward about 3 inches so it rests on the a-arm cover (tech term). Right now the weight of the car is resting on the a-arm bushing.
Old 04-25-2003, 09:52 AM
Friend of Warren
You need to move it forward and place where I circled in yellow. Right now you have it in a place that could possibly damage the torsion bar or housing.
Kurt V
Old 04-25-2003, 09:55 AM
brandett's Avatar
Ok, will do. Thanks.
Itīs my hobby.
911 SC -82 coupe.
My Project
Old 04-25-2003, 10:12 AM
s_wilwerding's Avatar
Absolutely, positiviely, never place the jack stand where you have the red rectangle. That is merely a belly pan that protects the steering rack - it is not meant to support the weight of the car.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 04-25-2003, 12:50 PM
HarryD's Avatar
I have always been told to put the jack stand behiond the front wheel where the three parts of sheet metal join to form the base of the A-pillar. In car later than mine, there is a flat plate welded there by the factory for this purpose. This spot has the advanatge of allowing you to work on the front suspension as well.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-26-2003, 07:12 PM
Navin Johnson
TimT's Avatar
why the **** do you ask if something you have done is OK after you have done it?
Check this out..... ask the BBS.... use the advice.. then apply...
'69 911 GT-5
'75 914 GT-3
and others
Old 04-26-2003, 07:18 PM
ckelly's Avatar
geez, maybe he did it with good intent and just wanted to make absolutely sure. I'd rather have someone ask at any point in time, stupid or not stupid, before or after, rather than have them get hurt or damage their car just because they didn't want to get razzed here.....
Haven't you ever done something, only to second guess your best judgement??
Clay
'80 SC coupe
Old 04-26-2003, 08:53 PM
brandett's Avatar
Normally i would let this pass, but Tim read my post and you will se "according to my studies". The picture in 101 projects is not 100 %...
Calm down, take a beer and relax...
Itīs my hobby.
911 SC -82 coupe.
My Project
Old 04-27-2003, 01:07 AM
Cut him a little slack. I've looked at the factory maunal, bentley, asked questions on this and rennlist, and read every post about the front end floor jack techniques and I'm still confused. Every time I do it I do it differently and see pitfals to every method. You can even see conflicting info in just this thread
Old 04-27-2003, 09:19 AM
Why not a little to the rear where that bracket is flat? Between the two bolts.
Thats where I did it last time. What did I damage?
Old 04-27-2003, 09:32 AM
randywebb's Avatar
I agree - I'd put it on the flat part, in between the two points indicated.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-08-2005, 11:26 AM
I agree with Randy and Rick, I used that spot and the jack stand cradle fit nicely with the bolts and cover......
Glad I got it right
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 04-08-2005, 11:48 AM
Recreational User
porschenut's Avatar
Yup, right between the two bolts....
Old 04-08-2005, 07:46 PM
