Advantages/Disadvantages to hollowing out cat
The cat converter on my 911 is plugged up and needs replacing.
There is no smog testing here during state inspection. Considering hollowing out my cat rather than buying a new unit. Advantages/Disadvantages to doing this? Im sure alot more disadvantages. |
One thing for sure, the exhaust will stink like a pre-cat car. Would probably sound better, though.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
STINK!!! Porsche hydrocarbon perfume........just like that VW!!
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
I've run an SC and a Carrera without a Cat, neither one of them caused a stink. Not sure where that claim comes from.
Kurt |
3.2 Scart exhaust with Scart pre muffler no stink.
Just Great melody
gearhead
Just buy a cat bypass and bolt it in.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I second the cat bypass.
Your dead cat is worth money. Get a bypass pipe and sell the dead cat to a recycler.
Driver
Through the local canyons I have followed a friend (many times) who only bolts in his cat for bienniel smogging. I can smell him clearly.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Crotchety Old Bastard
Heavy exhaust smell after removing a cat can typically be remedied by tuning up the engine and mixture setting. Catalytic converters cover this up as the engine ages. A well tuned SC or Carrera will not stink badly after cold start. Gutting a cat reduces back pressure but that's about it. The result is not a nice smooth path of flow for the exhaust. If looking for performance best to get a piece that is properly designed for that function. I think I know a guy that can hook you up.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
a bypass pipe / pre muffler allows for more room to valve adjust . Im not sure how much a bypass goes for these days but recycling the cat will likely pay for most of it. I kept mine as it was still good but who knows when the state might decide you need one again. As for the smell I prefer the smell without than the nasty stench a cat puts off. I wouldnt hollow it out. Its just a very teenagerish thing to do. Not on a porsche anyway. I know this because i did it when i was a teenager
82 SC , 72 914 |
No cat, no problem, no smell but more hers-purr-wers.
Ole Skool - wouldn't have it any other way |
cycling has-been
FWIW, the salvage yards around here are buying cats for $75.
73 911T MFI, 76 912E, 77 Turbo Carrera |
1988 Carrera
A hollow cat is still a big heat producer. GO with the bypass pipe.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
My vote is to splurge and get the M&K active exhaust -- https://mkexhaust.com/active-exhaust-with-pre-muffler/ -- the cat version transformed my car (when at/towards WOT, I appreciate both the additional kick and aural pleasure produced by the open(ing) bypass valve and would expect the non-cat version to do more-so with both.
Will the M&K active exhaust pass CA smog test?
_______________________________________________ 45 yr addiction 1965 356 Coupe, '70 914- POS, '74 911- lightweightFUN, '83 SC Cab- 100%AnalogOpenTop. |
Any cat or pre-muffler can be plugged into the active exhaust. We have a CARB approved cat that is used for those in CA.
"There is no smog testing here during state inspection"
SSIs and matching muffler for sure then. Surprised no one mentioned it. |
Eva
Bypass pipe all day long.
Cat is heavy and there's no point of ruining a good cat when a bypass is like $250. The car will smell, how it's supposed to smell.
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
I've run hollowed factory cat on a 3.2. I like that it appeared as stock. I consider it a "stealth bypass." Car ran STRONG (albeit it also had an open air box, Web 20/21 cams, Dansk 84mm Sport muffler and a Steve Wong dyno tune)...
![]() Stock cat weighs 13.85 lbs. ![]() Gutted stock cat weighs 10.21 lbs. ![]() I run an M&K Active Exhaust pre-muffler on my 3.4. It weighs 8.75 lbs. I have yet to dyno tune / test this engine. ![]() Yes, I have a problem...
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
