Location: behind the redwood curtain, (humboldt county) california
Suspension rebuild - how long/miles to "settle" before final alignment/cornerweight
I have seen many references to new/refreshed suspension "settling".
New bilstein HDs, 21-27 bars, HD rubber bushings, F/R.
How long does it take???miles/days???
How much will a suspension settle??
Will it do so evenly, or will things settle differently?
I plan to do a rough alignment, (string), then set heights/weights. If i had a rough average, or expected settlement, i could plan for it. If it is small, i might not need to do a realignment/cornerweighting.
I've only done this once before to a non porsche, so this is a whole new ball game.
Thanks,chris
Old 05-18-2021, 03:00 PM
I think a few miles and most of the settling will be done
Old 05-18-2021, 03:34 PM
It's a 914 ...
stownsen914's Avatar
I always thought a trip down the driveway was enough. Will be curious to know if more than that is needed.
Old 05-18-2021, 06:34 PM
Enough to compress everything a few times , so I trip to the local “rough” cobble road , or through the housing estates with speed bumps was what I was taught .
Back to check after that , then final check after 500 miles so was allways timed to do tyres or mot 500 miles after alignment .
Old 05-18-2021, 06:56 PM
Alan L's Avatar
Around the block basically.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 05-19-2021, 12:57 AM
Thanks Guys,
Ill rough in the alignment, then give it a short run before the corner weight and alignment.
chris
Old 05-19-2021, 07:24 AM
