Valve Guide drill bit source needed
I used to get them from Baum tools. Jerry Woods Had them for a while IIRC. Getting a batch made from a tooling outfit isn't cheap. Any idea who still stocks them?
Pilot end is 9mm to fit the guide bore.
Drill bit OD is 11.80mm/.464".
I'm down to my last one.
206 637 4071
Old 12-18-2020, 01:48 PM
Could you make a few step drills using your metal lathe, a toolpost grinder (or even a Dremel mounted to the toolpost) and the correct-size drill bits (.464" O.D.)?
Nix
'82 SC Targa
'83 SC Cabriolet
Old 12-18-2020, 06:14 PM
That's fond- just deglaze
Apologies John- not much data out there. Using the Wayback Machine, I was able to find the old listing from the Baum Tools online catalog for May of 2005. Below is the main image clip. The pop-out was not available, but it references Tool #87 as well. Hopefully, this helps in the search...
Link: https://web.archive.org/web/20050507123638/http://tools.baumtools.com/index.jsp?menu=por&newIndex=3&index=11&make=por&model=&part_number=&primary_section=&secondary_section=&tool_use=
Missed Approach
Petra- 1986 Coupe
Old 12-18-2020, 06:47 PM
Baum said they didn't have them, but I'll try calling with the number 86B.
206 637 4071
Old 12-18-2020, 07:00 PM
Charles Freeborn's Avatar
Looks like a modified twist drill bit. A good machinist with a grinding attachment on a lathe and the proper sized collet could knock out a batch reasonably quickly. Mc Master will have the core bit.
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 12-18-2020, 07:06 PM
Under the radar
Trackrash's Avatar
Nix
I have done this. Takes time, fiddling, and knowledgeable use of a lathe with a tool post grinder then finished with a drimel, but is do-able for a DIYer.
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-18-2020, 07:33 PM
Don't have a tool post grinder. Rather buy several. Already priced getting some made and it's out of hand. Must be some out there for sale.
206 637 4071
Old 12-18-2020, 09:37 PM
Jeff Alton's Avatar
John,
I will poke around as we would buy a bunch as well.
www.turn3autosport.com
Old 12-18-2020, 10:04 PM
otto_kretschmer's Avatar
can you go to .492 OD?
https://www.cylinderheadsupply.com/dcmkwikway.html
item 7211 is sorta kinda close
all you're doing is drilling out the old guide and leaving a shoulder so you can pound it out?
Old 12-18-2020, 10:07 PM
maybe another
https://www.mcmaster.com/29525A56/
I don't have the stem diameter so I looked at my BMW motorcycle book and the airheads use 8mm stems.
Old 12-18-2020, 10:23 PM
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 12-19-2020, 05:59 AM
John - I suspect there are many Seattle-area shops making custom machining / cutting tools for the local aerospace industry. I did a quick Google search and came up with this one:
Cutting Tool Control, Inc
I'm sure there are others. If you know somebody local in the machine-shop business, they may have a favorite tool grinding service they use.
Old 12-19-2020, 07:33 AM
Originally Posted by Jeff Alton View Post
John,
Hey Jeff you may want to reach out to Modern Engineering on River Road, they may be able to help.
Cheers,
Andrew
Old 12-19-2020, 08:46 AM
Cutting tool control did the last batch, but new people in there now that are less than cooperative.
Swift tool wants $149 for one and $84 each for six. Gotta be a better deal.
206 637 4071
Old 12-19-2020, 09:11 AM
If the OD is much larger, the remaining shell is thinner and I fear it could break from the driven part and remain in the bore. The size I have now works fine.
206 637 4071
Old 12-19-2020, 09:20 AM
They were ready made and available several years ago, just for drilling out 911 guides, so there should be a source from the past that provided them.
206 637 4071
Old 12-19-2020, 05:09 PM
Jeff Alton's Avatar
Cheers,
Andrew
Thanks!
Old 12-19-2020, 06:00 PM
Since this has the same layout as a drill piloted counter bore, what stops you from sharpening the current ones you have?
The drill point is pretty standard and the counter bore portion can be sharpened on a tool grinder. Same operation as tip sharpening an endmill.
Old 12-19-2020, 06:02 PM
the one I found on McMaster Carr has a big ID of .469 and a small ID of .313 (8 mm) and they want $59
this should work and I doubt you will beat the price
Old 12-19-2020, 07:09 PM
But I need a 9mm pilot. 8mm works for a 993. I have those.
206 637 4071
Old 12-19-2020, 09:54 PM
