Removing ac 83sc help please :)
It’s in the drive side rear front of the well. Can it come out or is it needed for another system in the car? It’s not the drier that would be in the front right? Last edited by harv666; 12-19-2020 at 11:13 AM.. |
Reiver
That is aftermarket so can be removed....
De Oppresso Liber Strength and Honor 5th Legion |
It is the reciever dryer, not sure what the smaller wires? Hoses? Are for so be careful removing. Yes it goes too.
Thank you, other wires went to it and then back to a mess in the rear fuse panel area, couple of relays that weren't hooked to anything. Glad its all gone now
The switch wiring was probably for a high low AC pressure switch.
That would make a lot of sense. Thank you. I love the knowledge on this forum.
