Yes, what a waste of rare Bosch CDI unit to incorporate a Mickey_Mouse aftermarket design.
Those Bosch eight pin 8 CDIs, i.e. used on the early 930s & BMW race cars which rarely if ever fail, typically sell for $1,000 - $1500.
Dave |
79 SC Back to Basics! 2006 997 C2s Cabrio - Sold 1999 996 C2 - Sold |
Ivan
But now we know why.
Who is that supplier?
Dave |
That PCB does not have solder mask on it. All the traces are open to the environment. Plus the PCB doesn't look like it was cleaned after final soldering. Is this a prototype board or a production board?
Find Spoke's LED Products: www.spokeworksled.com |
The CDI went on my 2-stroke hovercraft, I probably messed it up by allowing the battery to die. I eventually removed the electric starter and battery and just used the pull rope to start, but the intermittent problem persisted until I replaced the coil and CDI at the same time.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Have to love the way the components are mounted for an automotive application/reliability, right?
Dave |
Caveman Hammer Mechanic
My alternator would provide 13.9-14.1 with German precision, then occasionally(once a month on a daily driver) would spike to 16-17v as per my installed voltmeter. My tach was the telltale, it spazzed out and the needle waved like a flag in a hurricane. Shortly there after my YellowBox speedo correction unit died followed by the speedo then the tach. 4 dead CDIs is a huge telltale, if they were infact dead.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Hmmmmm....Sounds like the wires behind the ignition switch. The spade connectors there expand and contract over time and eventually loosen to cause intermittent starting issues. This happened to my best friend's 930 at a car show. The car started right up after wiggling the wires. Be sure to please disconnect the battery before attempting to tighten those wires..... Unplug each spade and ever so slight with needle pliers squeeze each connector, also be sure to clean the connectors with a little sandpaper. Hope this helps... Last edited by madkow; 12-29-2020 at 04:23 PM.. |
Ivan, when your car have a puff puff sound or oscillation in the baffel plate when starting it’s fuel related. If your car have puff puff sound in the exhaust then is electrical related. Maybe fuel injectors issues.
Lash
CDI printed circuit board, looks like a couple components have been replaced along with trace repair. I would consider the circuit board suspect and most likely causing your intermittent problem. Cold solder joint issues.
Lash 1963 356 T-6 Normal Coupe 1972 911 T Coupe ..... Sold 1972 911 S Targa ...... Sold 1980 911 SC Coupe Weissach |
Your CDI must be bad or dead now but if your car have intermittent electrical issues in a CDI or in a ignition distributor your car will have back firing when starting or running.
Concerning your 930 intermittent starting issue.
I would double check the plate height in the air flow housing and make sure it is set to the correct position. i believe that is - the plate even with the edge of the venturi. On cranking of the starter causes downward movement and activates the pumps. It is important that the plate is in the correct position.. Perhaps also check the relay for the air sensor and maybe the charge pressure switch in the intake. best of luck with this, you deserve it! Easy ED PS: unplugging the safety switch is another option and quick check ! |
I will be changing to a Bosch 6-pin CDI. I am thinking, how susceptible can these printed circuit boards be? One thing that is way different from my SC on the 930 is that it runs HOT! Temperatures inside the engine bay are extreme! Maybe this is the cause of all these circuit board CDI failures? Anyway I order a 6-pin CDI from a fellow forum member, will update once I get the car running again with the new CDI box. I am also waiting for a new set of fuel gauges to post system pressures.
Still thinking CSV. You have reported the components appear to be functional.
As a test, you can pull the wire to the CSV, attach your voltmeter between the lead and ground and with the car cold, crank the engine and see if you have power to the CSV. I would advise NOT messing with the CIS until you have ensured all other systems are functional. OLD SAYING: “There are 3 types of CIS Owners: 1) The guys with working CIS systems are probably out driving their cars so they won't reply. 2) The guys that tinker with their CIS systems and have them royally screwed up will keep you running in circles with suggestions. 3) The guys that have spent a fortune on Webers will tell you they're great to justify their expenditure to themselves. Your choice.”
cycling has-been
![]() nice one Harry
73 911T MFI, 76 912E, 77 Turbo Carrera |
