86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Distributor Cap Resistance
Per the Bentley.
Measured value.
The cap is new.
So, what is the correct value?
Is there a resistor in the tower connection?
Thanks in advance,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-23-2015, 04:40 PM
Member 911 Anonymous
DRACO A5OG's Avatar
I usually check the OHMs on the Rotor, if bad I replace as a pair. Nearly Zero, WTD??? If you are an optimist, 0.4999 would be nearly Zero right or would that be nearer to zero???
'85 Carrera Targa
PCA/POC
Old 09-23-2015, 05:43 PM
Resistance value.
Don't know.
But, according to the Bentley, it sold be a short. 0 Ohms.
I am replacing both the cap and the rotor.
G.
1986 911 Targa.
Only in L.A.:
Old 09-24-2015, 06:55 AM
DRACO A5OG's Avatar
Hey Doc, check OHMs on ref & speed sensor.
If you like you can place your DME in my car to insure that is okay too.
Let me know,
J
'85 Carrera Targa
PCA/POC
Old 09-24-2015, 07:30 AM
Pull out the carbon and spring and check it.
206 637 4071
Old 09-24-2015, 07:55 AM
Well that was interesting.... I had an old cap sitting here
  1. 5.8 k Ohms (variable reading)
  2. 1.048 k Ohms
  3. 1.026 k Ohms
  4. 1.138 k Ohms
  5. open
  6. 1.58 k Ohms
Center was 5 meg
The numbers are just from a line on the side of the cap
Rick
88 Cab
Old 09-24-2015, 08:09 AM
Carbon.
Why would there be a carbon resistance in the center coil tap?
RFI?
Back to my original question, is the Bentley wrong?
G.
1986 911 Targa.
Only in L.A.:
Old 09-24-2015, 08:59 AM
G.
Less than perfect contact between carbon, spring and terminal. Basically a non-problem.
206 637 4071
Old 09-24-2015, 09:24 AM
T77911S's Avatar
i just checked mine at it was 25 ohms
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-24-2015, 04:35 PM
Resurrecting this older thread - What should the cap resistance be?
Manuals say replace if the resistance is not near zero.
I have checked two Bosch 1235522368 caps and the resistance is 1025 ohms, +/-50.
That is consistent enough to make me wonder if the manual is a misprint.
I don't understand why there would be a resistor built into the cap as well as into the plug leads.
BTW, the plug leads are all 3K ohms, but the coil lead is zero. I can't find a spec for the coil lead.
Leads are all OEM Beru.
Any insight on this? I suspect I have change a couple of distributor caps unnecessarily.
Bob D.
'84 Carrera - MAF, Wong chip, RSR flywheel, ER bushings and other bits, CTR fiberglass F/R bumpers, 7/9 Fuchs, 21/27 TB, 22/21 SB, bunch of other little stuff
'74 Fiat X1/9
2021 X5
Old 07-01-2019, 07:17 AM
proporsche's Avatar
i think so too, no need to measure the cap ..i have never done ..never had a reason;-) put it on and drive.....specially new cap as said above
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-01-2019, 07:45 AM
Yes. Throw $$ at it and build up a potential stockpile of parts, in this case distributor caps.
Multiple caps have measured 1K ohms. Some not. I suspect it could be the manufacturer's attempt at reducing RFI (in select markets?) that might interfere with the operation of electronic control units (and indirectly, sell more caps). Put it out there on the internet and see what they say. This bubble is perhaps not large enough to provide all pertinent data.
Sherwood
Old 07-01-2019, 09:27 AM
T77911S's Avatar
does it matter if it is an HEI cap
RACE CAR:: sold
Old 07-01-2019, 09:35 AM
Senior Member
Superman's Avatar
My friend Sherwood threw out some stuff I'm not sure I agree with or understand but there is certainly some truth there. Beru spark plug ends have 1K resistance and the spark plug connectors have even more than that. From hazy recollection: 5K?
They do this to avoid radio interference. My car has no radio so I don't care, but I will tell you this: High voltage electricity will excitedly follow the path of least resistance. It will jump tens of centimeters. It will easily jump 1K Ohms. Unless it sees a quicker path.
bottom line: This cap will faithfully pass that signal to that spark plug. Unless it gets dirty inside.
Mocha 1978 911SC. "Coco"
Old 07-01-2019, 09:26 PM
The caps I have are working; this is really just about clarifying what the Porsche and Bentley manuals say.
It seems that the manuals instructions to replace a cap if the resistance is not zero should be ignored and a spec of about 1K ohms should be used.
Bob D.
'74 Fiat X1/9
2021 X5
Old 07-02-2019, 08:10 AM
What should the resistance be between the post in the centre of the cap (goes to coil) and the button on the inside?
I have 2 caps.. one is showing 1k ohm.. the other is showing 1 M ohm..
Old 01-17-2021, 01:51 AM
proporsche's Avatar
mike.don`t worry about it;-)
Ivan
Old 01-17-2021, 01:57 AM
Ivan
Seriously?
Old 01-17-2021, 02:03 AM
proporsche's Avatar
yes..........;-) plus....as John said post #8.......
Ivan
is there a reason other than the book mentioned above???
Old 01-17-2021, 04:19 AM
I don't get why anyone would use or pay attention to anything in a Bentley manual? It is the Readers Digest of car stuff.
Get or download the real thing if you need it.
Old 01-17-2021, 07:14 AM
