Air box is blown..u would invest on a new one
And install the pop off valve. Things are adding up Fast. |
Looks like a blown air box. I would invest on a new one
Install pop off valve. Things are adding up fast.! |
Yeah that cut off line should be feeding your tensioners. Will be interesting to pull the timing chain covers and see what kind of trnsioenrs you have....
I’d fix your airbox. Bolts/nuts will make clamping force. For the epoxy make sure you get something that bonds to ABS. This is just me but I can deal with total scatter. Tearing down cis is fine but just do on step at a time or you might lose parts. Sent from my iPhone using Tapatalk
IG@ADDvanced Youtube@ADDvanced www.gruvdesign.com |
CIS troubleshooting.........
Neil, Your major problem is the cracked air box. No wonder you were having so much problem in troubleshooting. How many times did I ask you to do a smoke test? Re-seal the are box using either bigger metal screws or nuts & bolts. And pressure test before installation. The air flow unit’s gasket is primarily a dust shield. Even without a gasket, it would not affect your CIS. Why? The AFM is under atmosphere condition like the air filter. The gasket comes in different materials (foam, paper, or cork). The oil line by cylinder 1-2-3 is for a Carrera hydraulic fed tensioners and was modified/cut to work with your engine. I don’t think you have a Carrera 3.2 tensioner installed now in your motor. Could you post a picture of the 3-4-5 chain housing cover? You would need a lot of patience to get this motor cleaned up. Keep us posted. Tony |
Planning to fix this airbox Scatter is ok until it sits there for 6 months. That’s when I get into trouble. |
Here are the pics you requested ![]() ![]() Thanks for any replies! |
PS Tony
You are right about patience needed. Good thing I am retired have plenty of time. I will clean the engine as best I can to improve its appearance but not going to go crazy making it look new. I have a long list of items to check and/or repair and if I can clean up along the way so much the better. This will never be a show car. Pressure washer supposed to be here tomorrow. We will see how it looks afterwards and go from there. |
Cleaned the air box today.
Put in flashlight in one of the intake ports opposite the seam crack. ![]() The crack is under the two lower openings in this picture. No light shows through. The injector sleeves were a real mess. I believe a lot more air coming through each of them. I have new sleeve O rings. |
All pressure washed. Not as clean as I would like but as clean as I can get with a sprayer. An improvement for sure though.
![]() Found this on the ground after I cleaned up. Anyone recognize it? The washer may have just blown it out of a crevice on the motor somewhere. Looks like something from around the clutch arm. Last edited by Funracer; 01-26-2021 at 11:07 AM.. |
![]() Note the capped off oil line above the tensioner opening. I assume these are original tensioners not the upgraded Carrera version. If that is so I will replace the oil line with the correct original version and order two tensioner rebuild kits and tensioner guard kit from PP. The Carrera tensioner kits are outside my budget unfortunately. Maybe next time. Does this sound like a good plan? Thanks |
If they aren't in your budget, buy them with a credit card. If those mechanical ones fail, which they can, your engine is donezo and you're going to need to pull it all the way apart. Unfamiliar with tensioner guard... if that can prevent failure maybe that is a more cost effective way.
Good idea with new lines, they aren't too much $.
the pin you found is from your rear decklid shock absorber(hood shock)..not to worry ...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 01-26-2021 at 02:55 PM.. |
that's a securing pin for either hood/lid shocks or the door band to A-pillar
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
though follow application rules. don't let it soak too long on bare cast Aluminium (20-30 minutues should do the job anyway).
Any issues with the Sebro kit? Thanks Last edited by Funracer; 01-27-2021 at 08:23 AM.. |
