Engine conked out
Hey Guys, so I was warming the 83SC in the garage this morning. After about 10 minutes the engine just died. I tried to restart it and it just cranked over real fast, that was it. Got any ideas what to look at first? Thanks.
Old 01-10-2021, 08:13 AM
proporsche's Avatar
check your fuse number 6 from the windshield--you should have fuse box cover with fuse index on it--then report
Ivan
i assume you know where fuses are?
1985 911 with original 502 191 miles...808 198 km
Old 01-10-2021, 08:22 AM
Ivan, that was it, the fuse fell apart when I touched it. Do you know the value of that and what it is for?
Old 01-10-2021, 10:04 AM
It’s fuel pump fuse
The value might be inside the cover, it is in the manuals.
Bruce
Old 01-10-2021, 10:33 AM
proporsche's Avatar
fuse for fuel pump is usually blue 30A....also check the others .If they are plastic look o-line cor ceramic fuses ,thay last longer and can take the heat...
Ivan
Old 01-10-2021, 10:46 AM
Thanks guys, fuses ordered.
Old 01-10-2021, 10:50 AM
Did you find ceramic fuses, if so where? Our host is out of stock.
Jason
'79 911SC Targa
Old 01-10-2021, 03:08 PM
Slow old car
Jason
2nd.
Also, beware cheap fuses: they’ll melt and leave you stranded.
Mike
1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX
Old 01-10-2021, 03:19 PM
I ordered thru pelican, I guess they are plastic
Old 01-10-2021, 03:34 PM
Still here
pmax's Avatar
Fuel pump on its way out ?
Old 01-10-2021, 03:55 PM
What’s the normal current flow? I can put a clamp on on it,
Old 01-10-2021, 04:37 PM
proporsche's Avatar
hook..if would like i have plenty of ceramic fuses...you can have some for free,just have to pay for postage..
In case you will not be happy with the plastic.Or cannot find ceramic ..
Ivan
Old 01-12-2021, 11:25 AM
I believe the German Flosser brand torpedo fuses are known to be high quality. They have the ceramic body. Inexpensive and readily available on Ebay, just buy from a reputable seller.
1978 SC Targa
Old 01-12-2021, 02:30 PM
You can try Memotronics. They have ceramics except for 8amp (white) which are impossible to find in my experience.
Old 01-12-2021, 07:44 PM
Brown747's Avatar
Time to upgrade to modern blade fuses. Host has the kit.
https://www.pelicanparts.com/More_Info/RFZ7483.htm?pn=RFZ-74-83&bt=Y&fs=0&SVSVSI=790
I did it to my car last summer. Took an afternoon. Recommended
Thor
1978 SC coupe #1834
Old 01-12-2021, 09:21 PM
Ivan
Thanks Ivan
Old 01-13-2021, 12:38 PM
proporsche's Avatar
Thanks Ivan
no problem .if you need, you know where to find me
Ivan
Old 01-13-2021, 02:02 PM
Thor
On my to-do list for my SC. Just did my 914 race car as a break-in. . .
Don Newton
“People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.”
"I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams
Old 01-13-2021, 02:42 PM
I just received plastic 16 amp + 8 amp fuses, whereas product description was ceramic (not our host).
Send 'em back, or just live with them?
Jason
'79 911SC Targa
Old 01-19-2021, 10:37 AM
MBAtarga's Avatar
I'd say plastic composite shouldn't impact performance.
Mark
'83 SC Targa - since 5/5/2001
Old 01-19-2021, 11:14 AM
