RETIRED
Just purchased a solid state DME from Forcus 9....
So whatya think? Keep the spare analog one that replaced the failed one or offer it for a date with someone's sister in GA?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 02-25-2021 at 06:44 PM.. |
Diss Member
Did you get a 944 that isn't listed in your signature? Looked through their site and it only lists 2 944 DMEs.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
RETIRED
Well I was led to believe it works for my 964 motor. If'n it don't wellllll, I'll be irked. I usually can still read and comprehend when I'm pissed off and drinking but there be always the first time.
God I hope this ain't ain't another "Coboy" incident.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I had one in the 968 and one in the 944S, for the last couple of years.
So far, happy.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
RETIRED
Well Wayne, you're right.
Wrong pins. Flat pins on the F/9 relay versus round uns for the one in my ride. Part number was off as well. .00 versus .01
Back to your original question, while carrying a spare DME relay has served the faithful for decades, I'd say you don't need to with the solid state unit. In fact, save the space and weight, carry a DME jumper harness in the unlikely scenario your F9 unit fails.
I've had two 3.2s with the pump prime units. Love 'em.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Diss Member
I was thinking "DAMN that is a lot of work to re-engineer the whole DME!" The thread on Rennlist makes it seem like it is possible that it is a ground up new box. Can't understand why they wouldn't do the work to make a 911 version. That would sell better.
Diss Member
If the pins are equivalent on the 944 unit I would be inclined to just build short jumpers from blades to bullet connectors and use it.
3.6 964 transplant in my '82SC. I had forgot that when I did the transplant back in 1992 I wired a 3.2 (round pin) DME into the 964 wiring harness under the seat. I'm sure yours is the same. The original 964 DME wiring goes up to the 964 relay console under the frunk and uses the flat pin relay. I have had the Carrera 3.2 Solid State relay (with prime function) in my car for 8-9 year and has been flawless. Love the prime function as it's comforting to hear the pump run for three seconds before you crank the motor.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
I have had the fuel pump prime version for a couple of years. I carry the spare because it is small, and weighs only ounces. Once before on a club drive one of the other 3.2 Carrera was having running issues. I let him borrow my used relay and he got home, and ordered the solid state once. He gave back the old one.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
RETIRED
Well the one I received doesn't fit my set up. I've emailed the support team and I'll see what happens.
Seems to be a good seller.
RETIRED
I'm sending it back for a refund.
