930 Rear Trailing Arm Pick Points
Im going to be fitting 930 arms on my rsr build. I have the new boxed pick points. Does anyone have the dimensions or jig needed to fit these? I dont want to wing it. Any advice is appreciated. Thanks.
If you bought weld-in boxes, you might check with the vender to see if they have dimensions they could share.
I know these guys used to build and sell these: http://johnjamesracing.com Here are some instructions I found on the Tarett website. No dimensions that I could see, but maybe helpful nonetheless... interesting that they have JJR's name on them. ![]() ![]() ![]() ![]()
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Thanks. These are by the non adjustable type. Just a raised version that gets welded on to the factory one like pictured above.
Thread Tools | |
Rate This Thread | |
