Slow old car
Lambda relay pinout?
I’m looking to wire up my wideband O2, and thought rather than running a new wire from the fuse panel, I might be able to use the now-abandoned lambda wiring for a switched wire. (My fueling was backdated to a C3.0 system)
Anyone have guidance on what each wire on that relay does? No luck via search.
Mike
Mike
1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX
Old 02-17-2021, 02:45 PM
Slow old car
Anyone??
Mike
Old 02-18-2021, 07:42 PM
What year wire diagram are you looking for ? I can find that with a bit of help about it.
1985 Carrera 3.2
Old 02-18-2021, 11:24 PM
looking at an 83, red wire at 30 is battery and red and white at 86 should be switched current and 85 is brown/ground. Lambda relay under the passenger seat.
Old 02-19-2021, 06:28 AM
Slow old car
Just a regular dpst relay setup then,ok! I thought somehow it acted as the controller for the frequency valve, so I wanted to be careful about using a + from something that may not always have it
Thanks!
Mike
Old 02-19-2021, 07:54 AM
It serves the Lambda controller along with the fuel pump relay. The Lambda controller serves the frequency valve. If you are not running late CIS, then there is nothing to disturb. Assuming your gauge will be in the dash, probably less routing to go to the fuse box or ignition switch with an inline fuse.
Old 02-19-2021, 12:55 PM
