Whale tail upgrade value shock fix
So after looking around for ways to get 2 struts fitted and not distort my new whale tail upgrade I decided to go my own route. Turbo right hand hinge with strut mount was rare as hens teeth or over $100 plus color matching. Double shock on left side would not have worked for me, twisting and distortion would frustrate me. Aluminum $270 hinge kits too expensive. So my Value fix was to add a piece of steel to current hinge, weld in place and spray to color match. Wow what a solution worked so well! Looks neat and not an add on. Took approx 2hrs including spraying.
I recommend this method and would gladly assist anyone wanting same fix.
With new HD shocks it holds high and proud
Old 03-01-2021, 01:08 PM
Congrats! But share a photo!
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 03-01-2021, 01:21 PM
Have been attempting that! However mobile app has flaws. They were uploaded so trying alternative method on pc
Old 03-01-2021, 01:23 PM
Old 03-01-2021, 01:39 PM
aj88cab's Avatar
Nice work! i don't need to do this, but I am curious.
The new piece of metal is formed. Did you form it or cut it off something already formed?
That bracket is pretty light/thin steel. MIG or TIG?
With my (MIG only) welding skills I'd of blown thru that metal like a bullet!
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 03-02-2021, 06:54 AM
Nice job.
On my 87, I found that chassis had a mount when replacing the sound pad.
What did you do for the chassis mount?
Old 03-02-2021, 07:47 AM
Any pics of the firewall side? My 83, has nothing on the firewall and an oil return line in the way
Old 03-02-2021, 08:47 AM
'82 SC TL
canamfan's Avatar
Nice work! IMO you definitely need two lid struts on a Turbo tail for even weight distribution & to prevent distortion. I tried 2 on one side (no good, started to distort slightly), I was lucky to find a OE Turbo right side hinge, painted, welded bracket in engine bay (did full resto then) & voila it's perfect.
76'S 1st Porsche white/can/can early rebuild (boo)
'84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1)
'87 Carrera cpe white/blue short flirt
'89 Anniv. sil/linen very pretty miss her
'88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Old 03-02-2021, 09:27 AM
It’s 5mm mild steel mig welded by myself, most solid metalwork on car zero flex
Old 03-04-2021, 06:51 PM
Originally Posted by HaroldMHedge View Post
Nice job.
Mine too I was also lucky it had one fitted but not previously used
Old 03-04-2021, 06:52 PM
That’s unlucky mine had one already on firewall. I think if it didn’t I would have waited until engine rebuild before welding in to firewall
Old 03-04-2021, 06:54 PM
I used gasless mig, I’m no expert and hinge material is pretty thick. Bought cheap mig unit from harbor freight, works great
Old 03-04-2021, 06:56 PM
10 years from now someone will be here asking if this was some uber rare factory mod
Old 03-04-2021, 06:59 PM
Thanks. Thats what I was afraid of. I just added a tea tray and its definitely leaning when open. Might have to go back to the stick for now.
Old 03-04-2021, 07:23 PM
after reviewing engine bay I feel with air box removed mig would definitely fit in there if required without an engine removal.
Old 03-05-2021, 03:27 PM
Thumbs up Tail addition
Project started as a non whale tail, purchased silver one with deckled from PCA member, resprayed in garage, what a pain that was with all the slats/grilles. cut & polish was difficult for beginner, two 2 resprays of grille section. Enjoyed the process, om no expert but looks amazing now. Added front lower spoiler too, parts geek was nearly half price of other suppliers.
Old 03-05-2021, 03:35 PM
looks awesome!
Old 03-10-2021, 01:24 PM
If you check PET, you will see that Porsche at one time made a bracket you could add to your right deck lid hinge. I think it is now NLA but I ended up making a few for my 83SC. I also bought a left side strut mount from a member who was cutting up a body, then welded it on (Twice) to the engine compartment wall
83 SC
Old 03-11-2021, 06:47 PM
The rear shelf bracket is "Gas strut bracket - 911 501 729 01". I bought a new one 2 years ago for ~$20
Old 03-12-2021, 07:44 AM
