Diff ID
I think this is a LS diff out of a street G50. Can anyone confirm that or identify it. Thanks, Bob
Old 03-28-2021, 04:02 PM
gearhead
GKN LSD for 993 or later. It has the part number stamped in the side. It could be any number of specifications.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 03-29-2021, 03:09 AM
Thank you. Bob
Old 03-30-2021, 06:11 AM
Bill Verburg's Avatar
#s on the side would look like this
if it's a 993 GKN the spec is either 22/40 unless it's from a 993RS trans
22/40 ramps look like this
22/40 part # 950.332.083.00 or .03
Bill Verburg
Old 03-30-2021, 12:32 PM
gearhead
Actually there are more options than that.
950.332.083.02 25/65% G50.20/21 95+
950.332.083.03 22/40% G6420/21
950.332.083.38 40/65% G50.30/31/32
1974 914 Bumble Bee
2009 Outback XT
Old 03-31-2021, 10:37 AM
950.332.083.00 22/40% G50.20/21 -95
950.332.083.38 46/65% G50.30/31/32
Your right, I need better glasses
the 22/40 was for a g64 anyway
funny my PET, shows different data for the -95
950.332.053.05 ZF 25/65 -95 g50/20, 21
950.332.083.02 GKN 25/65 96- g50/20, 21
950.332.083.38 GKN 25/65 96- g50/30, 31, 32
950.332.083.30 40/65 993RSR
950.332.083.33 40/65 993Cup
950.332.083.03 GKN 22/40 G64/20, 21
+ all the turbo and GT2 that I didn't bother to look up
Bill Verburg
Old 03-31-2021, 12:28 PM
gearhead
My PET didn't show the .00 so I just took your info at face value. I googled it and got no results so just assumed you were right on that one. I've just edited it out for clarity.
The break from ZF to GKN has always been hazy to me. They never offered a gearbox number break for the change like they did with the slide on 2nd gears.
1974 914 Bumble Bee
2009 Outback XT
Old 03-31-2021, 01:09 PM
I was told that this diff was for a street G50/1, a 3.2 car. I have old eyes, but I don't see any script on the side of the housing. Just the cap. Bob
Old 04-01-2021, 06:08 AM
If it's from a G50/01 then it's a 40/40 ZF 950.332.053.06
Bill Verburg
Old 04-01-2021, 07:25 AM
group911@aol.co's Avatar
And then there is the 083 01
Thanks,
Bob
group911@aol.com
Old 04-01-2021, 07:35 AM
What did that come from? looks like some 993 version
Bill Verburg
Old 04-01-2021, 07:43 AM
Or the 950 099 332.35??
Thanks,
Bob
group911@aol.com
Old 04-01-2021, 07:50 AM
I just have it labeled as GKN 2 plate?
Thanks,
Bob
group911@aol.com
Old 04-01-2021, 07:53 AM
gearhead
You were told wrong. Porsche used ZF for all of the 3.2s and 964s, and that is 100% a GKN LSD.
1974 914 Bumble Bee
2009 Outback XT
Old 04-01-2021, 08:13 AM
gearhead
If you guys want to get down the nitty gritty of it, you should open up the LSDs (just 3 screws) and look at the stamping on the pressure rings themselves.
These ramps are 26/65 and will be stamped 7&8 on one of the 4 ears that ride in the housing. I've got a list of most of them somewhere, but every set of pressure rings has a sequential pair of numbers on them indicating the ramps cut into them.
1974 914 Bumble Bee
2009 Outback XT
Old 04-01-2021, 09:25 AM
