Diff ID
I think this is a LS diff out of a street G50. Can anyone confirm that or identify it. Thanks, Bob
gearhead
GKN LSD for 993 or later. It has the part number stamped in the side. It could be any number of specifications.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Thank you. Bob
#s on the side would look like this
![]() if it's a 993 GKN the spec is either 22/40 unless it's from a 993RS trans 22/40 ramps look like this ![]() 22/40 part # 950.332.083.00 or .03
gearhead
950.332.083.02 25/65% G50.20/21 95+ 950.332.083.03 22/40% G6420/21 950.332.083.38 40/65% G50.30/31/32
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 Last edited by Matt Monson; 03-31-2021 at 01:11 PM.. |
the 22/40 was for a g64 anyway funny my PET, shows different data for the -95 950.332.053.05 ZF 25/65 -95 g50/20, 21 950.332.083.02 GKN 25/65 96- g50/20, 21 950.332.083.38 GKN 25/65 96- g50/30, 31, 32 950.332.083.30 40/65 993RSR 950.332.083.33 40/65 993Cup 950.332.083.03 GKN 22/40 G64/20, 21 + all the turbo and GT2 that I didn't bother to look up
gearhead
My PET didn't show the .00 so I just took your info at face value. I googled it and got no results so just assumed you were right on that one. I've just edited it out for clarity.
The break from ZF to GKN has always been hazy to me. They never offered a gearbox number break for the change like they did with the slide on 2nd gears.
I was told that this diff was for a street G50/1, a 3.2 car. I have old eyes, but I don't see any script on the side of the housing. Just the cap. Bob
And then there is the 083 01
What did that come from? looks like some 993 version
Or the 950 099 332.35??
I just have it labeled as GKN 2 plate?
gearhead
You were told wrong. Porsche used ZF for all of the 3.2s and 964s, and that is 100% a GKN LSD.
gearhead
If you guys want to get down the nitty gritty of it, you should open up the LSDs (just 3 screws) and look at the stamping on the pressure rings themselves.
These ramps are 26/65 and will be stamped 7&8 on one of the 4 ears that ride in the housing. I've got a list of most of them somewhere, but every set of pressure rings has a sequential pair of numbers on them indicating the ramps cut into them.
