Designer King
How to Refurbish Heater Controls?
The plastic parts of my between the seats heater control levers have faded to a pale pink. I seem to remember reading somewhere that they can be removed and placed in boiling water for a minute or so, and they will return to their original bright red.
I haven't been able to find anything on this via a search, but I think I've read it somewhere... Is this correct? Or is there some better, alternative method to do this?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Paul -- take a look at this thread -- Shift knob/heater knob restoration I googled "boil 911 heater control" to find it
Designer King
That's it! Thanks Darrin.
no problem, let us know how it turns out, mine still look quite red, but intrigued!
i redyed mine about 15 years ago , was pretty straight forward. need a steady hand and a fine brush for the lettering though. I have a Targa so it gets lots of UV. could need doing again but not bad for 15 years.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Paul,
I bought 2 new ones on eBay for $10 each and look great...... ![]()
Sean M '77 911S Targa Ice Green |
Speed Metal Army General
The dye works great! But instead of painting those letters... Get a white crayon and smoosh the wax into the voids. Old dungeons and dragons dice trick, works and looks perfect. Stays looking good too!
I think our host sells them. I found them brittle and hard to remove, prone to break. If they've turned whiteish, they've been baked, and mine were 30+ y/o at the time.
Just tried this with absolutely zero effect after 45 minutes. I used a cheap powdered dye from Walmart, maybe should have used RIT but they didn't have any red. Perhaps I'll give it another try down the road.
Walt 82SC 3.0 81SC 3.6 |
Thread Tools | |
Rate This Thread | |
