Dept store Quartermaster
Turbo sytem flow question.
I am 90% sure I know this answer, but just want to clarify. On a turbo motor the intake air whether on boost or not passes through the turbocharger itself correct? I mean the bypass valve simply opens to let excess pressure out, not to bypass the turbo when not on boost right? If I am correct, does this "restriction" have any real affect on low rpm response? Just wondering, thanks.
Cornpoppin' Pony Soldier |
I take it the Bypass valve is the same as a Wastegate. True?
Warren & Ron, may you rest in Peace. |
Got Boost?
Yes, it is used to avoid over pressure damage when the throttle plate is suddenly shut as in shifting and letting gas off. The air that is bled through the bypass has already been metered by the Air Flow Meter which goes immediately before the turbo intake on the turbine side.
What restriction are you refering to? I don't see any restrictions.
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work." -Ayrton Senna- |
Yes - intake air does go through the turbo first. Bypass valve opens when throttle plate is closed to prevent the turbo from slowing down.
Effects on low rpm... umm - probably some i guess but then the engine is not sucking a lot of air at that time.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
True, the compressor wheel is always spinning I would assume so I doubt it adds any restriction.
Got Boost?
lendaddy, you left me thinking, I guess the restriction you are talking about is that at low rpm the bypass valve would open until boost comes up. Well this is not really a restriction because the bypass will open under negative pressure or vacumm. Turbo engines go to positive pressure almost immediately when you get on the gas then takes a little longer to build up high pressure.
The bypass valve bypasses the comp. any time there is high vacume. So any time the throttle is closed the bypass valve is open, bypassing the turbo comp.
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Crotchety Old Bastard
The Throttle bypass valve does just that - it bypasses the throttle butterfly during off throttle events eliminating surging that would occur against the closed throttle plate from the still spinning turbo.
The wastegate opens at a specific pressure, such as 0.7bar, to control the engine compression under boost.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
The wastegate diverts exhaust around the turbine side when intake pressure gets high. WG springs and controllers can modify when/how the exhaust bleed happens. The bypass valve is triggered by vacuum that comes from behind the throttle body and fed to the small nipple. When there is enough vacuum on this line it lets the pressurized air from the compressor recirculate to the cold-side inlet. Some systems use a blow-OFF valve that isn't a good idea on pre-compressor MAF systems because it fools the ECU into believing more air is getting into the engine than there is. I don't get positive pressure imediately . I'm still under ambient (.8 absolute here) until I get up to around 2000 rpm. Wow, had to come back and fix this after 4 or 5 posts showed up before I was done typing the original version of this reply
BTW: Here's some BPV info put up by a gung-ho S4 quattro HP junky.
Look for the two links about Diverter Valves http://www.s4biturbo.com/index.html |
Got Boost?
thebaer, Thanks for the correction.
Thanks for the clarification.
