Bad noise from the fan
I just have a bad noise from the rear fan , seems like something is rubbing when the fan rotates but there is not any sign of rubbing on the external ring.
I suppose something wrong with the alternator , what do you think? I have a vid but think I can't post here. Thanks |
hi, yes you can post it, when you want to do the next ..go to advanced and there is a blue line for inserting pictures or video
Ivan also testing for the noise , disconnect the alt.belt and spin the fan by hands and feel for play...
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
That's fond- just deglaze
Caro ravenpower- This is the noise I was experiencing before I changed my alternator (the video is from Forum Member 911 Euro)...
https://www.youtube.com/watch?v=7O5r2Cu5yQc&feature=youtu.be and my full writeup: 1986 Alternator replacement- Rumbling noise now gone, hidden bolt on A/C plate Hope this helps! Cordiali Saluti
Missed Approach Petra- 1986 Coupe Last edited by Missed Approach; 03-17-2021 at 11:30 AM.. |
thank to you MA , same noise of the vid pretty sure is the alternator.
Thanks |
