Really dumb question
Okay, so the only really dumb questions are the ones you DON'T ask which results in you screwing up something really expensive.
Uhm, so where and how do I attach the chains from my hoist to lift a 911 engine high enough to get in on my workbench (unless someone's got a used yoke to sell or lend me)? Ducktail |
I'd either put it on a pallet and then hoist it, or just get a few friends and muscle it up there. They're not really that heavy with 3 or four guys.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Senior Member
There is a ring toward the back, on the top center of the case. It has no other purpose and I was told it is for lifting.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
On the front I use the mustache bar/ engine mount bar and on the back the ring mentioned above.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
you're right, that's a really dumb question....
(just kidding)
www.swirlednews.com/article.asp?artID=501 The data in the CD-type disc decodes easily into ASCII computer text as follows, using 8 bit binary: * "Beware the bearers of FALSE gifts & their BROKEN PROMISES. Much PAIN but still time. (Damaged Word). There is GOOD out there. We OPpose DECEPTION. Conduit CLOSING (BELL SOUND)” * The damaged word would appear to be intended as “BELIEVE”. |
Thanks gang. Don't have enough guys around to lift it. I found the "eye", but the "mustache bar" on back is missing (still on engine in car), so I have to figure something else. Tranny's not on, so I do need a back point. I'll check the mounting points for the mustache bar and see if I can't rig another "eye". Any other ideas, let me know.
