Mysterious Tachometer
Hello everyone,
It's my first post so thank you all for the advices and informations we can find on
pelican.
I have a question about my tach, I did a lot of research but I know there's people with
big Porsche knowledge here, so better ask.
My car is a 2.7 from December 73, one of the first 2.7 out from the factory.
All my gauges are stamped 07.73 so it seems that they used existing models maybe and my tach is an early style with black center never seen a tach like that and I don't think it was open. I'm the third owner.
Have you ever seen something like that ?
RC
Old 03-20-2021, 08:12 AM
Interesting... Never seen one like that before. Porsche is known for using up the old stock in transition years but that wouldn't really explain this one. It's the correct tach for a 2.7 with the high-beam indicator up top but it has the early needle with the silver button painted black. If it were a left over 73 tach the high-beam indicator would be at the bottom.
My guess is that it was opened up at some point and the needle what replaced, but nothing surprises me anymore. If it was done at a shop with the VDO tool to crimp on a new bezel you wouldn't be able to tell if it had been opened.
I'd be interested to know if anyone has seen another one like this.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 03-20-2021, 08:53 AM
304065's Avatar
Cant' tell anything without seeing the back of it.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-20-2021, 08:54 AM
Also, what is the part number printed on the upper lip of the face?
Old 03-20-2021, 08:57 AM
proporsche's Avatar
RC.go to the French forum if you are not already member and ask for Gedeon25 he is an expert in France for gauges;-)
type911.org
or you can find him here
stationcompteurs
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-20-2021, 09:25 AM
proporsche's Avatar
here is similar 1974 911S
Old 03-20-2021, 09:32 AM
Cool.. Never seen a speedo like that either.
RC: Does your speedo have the same needle with black center?
Old 03-20-2021, 09:36 AM
Thanks for the reply guys
No it's just the tacho, the speedo is the normal version for 2.7
Part number is 911 641 301 29 - 0001
This is a picture of the back
-911 2.7 73 with 3.0 engine
Old 03-20-2021, 10:13 AM
proporsche's Avatar
RC,it is very possible it has been apart ..the markings next to the screws..otherwise very interesting tacho ...
Ivan
Old 03-20-2021, 10:31 AM
Ivan
Yes it's the most likely scenario I guess
Old 03-20-2021, 10:46 AM
proporsche's Avatar
But,very nice piece and it is good to have something different..;-)
Ivan
Old 03-20-2021, 10:48 AM
304065's Avatar
So you have a tach made before the August factory closure, which would have been a 1973, and your car was made in December which makes it a 1974.
There is usually a witness mark of paint on the screws- that and the scratch marks around the screw heads and distortion of the slots suggest this tach was opened at some point for repairs, and the needle was replaced.
here's a photo of an early 74
https://www.caranddriver.com/photos/g17972433/1974-porsche-911-vs-911s-targa-911s-carrera-archived-comparison-test-gallery/?slide=29
'81 R65
Old 03-21-2021, 07:42 PM
Thanks for your answer, I found a picture of a black center early tach on a post,
maybe I will ask what's the story behind.
Old 03-22-2021, 08:02 AM
I notice your car has a 3.0 engine so maybe the tacho was swapped out for another to make it work ok with that engine?
Old 03-22-2021, 08:15 AM
That one is an earlier tach evident by the ivory versus white face. 68 through sometime in 71 were that off-white color.
Old 03-22-2021, 08:16 AM
No I swapped the engine recently but it had a 2.7 since the beginning.
Old 03-22-2021, 10:09 AM
LJ851's Avatar
The tach in my car is nearly identical. It has the same face, same part number but has a 7/75 build date.
The needle is the newer style like you would expect and the labels for each electrical terminal are cast into the plastic not printed on the metal housing like yours.
Old 03-22-2021, 03:38 PM
Walt Fricke's Avatar
This was a real 2.7RS, and you put a 3.0 in it?
Old 03-24-2021, 03:44 PM
No just a common 2.7
Old 03-25-2021, 02:49 AM
When I put a 3.0 into my '77 Euro 2.7, I was advised to change my tachometer. The earlier tachs got their signal from the distributor points. When the points went away, the six pin CD box had a dedicated (and cleaned up) tach output - a pretty clean 12V square wave. This supposedly would not work with the original tach, and an SC tach was what was recommended (which I did).
But you have an even earlier tach, so this doesn't quite make sense. My suspicion is that you can't easily convert these by changing some passive electronic components inside the tach, but maybe you (a knowledgeable shop) can?
Old 03-25-2021, 04:28 PM
