Member 911 Anonymous
DRACO A5OG's Avatar
Exclamation You Must CHECK the Rocker Shaft Bolts when you DIY Valve Adjust!
Hey Fellas,
Well, sort of a good and a bad day.
Yesterday, after a normal freeway round trip up to the valley, a hot day in the 90's, almost home, I heard and uneven engine tone, not steady but almost ossillating, then I decided to get some gas and check the oil level. Weird how we know the sound of our engines
DARN Lucky I did, well I hope.
While filling up the gas, idling for the oil level check, I heard a sudden "Plunk" like ball pin hammer to aluminum sound, then idle suddenly skipped and miss-fired and plunk plunk plunk. Well here is a video to better describe it:
Shut down, immediately! Well, after the video.
Looked below, found this abnormal oil puddle, I usually get a drip or two, but never ever this much in this short of a time span (??? * )
Called AAA & towed her home, geez, even on the flatbed, she still looks good to me
DAY 2:
Drug myself out of bed, not really wanting to face the music. Then I dove right in, head first.
The dreaded probing surgery, cracked opened the lower driver side valve cover to allow the oil to leak out the bottom ( I noted something here * )
Here is the culprit "plunking" noise
and it's evil sister and the real culprit ( the oil leaker too * ):
So now I see where I was getting the valve cover leaks. I always thought it was the cam shaft o-rings. Now it makes sense if the rocker shafts are loose, it also will seep out oil, WARNING SIGN!
So for the benefit of you DIYer valve adjustment guys, CHECK the darn Rocker Shaft bolts while you are in there. 11ft lbs or SNUG (credit TRE).
'85 Carrera Targa
PCA/POC
Old 02-11-2016, 11:33 AM
83 SC
tkmoore's Avatar
Great advice and I hope she is back up and running great again? Tim
Old 02-11-2016, 11:43 AM
356RS's Avatar
Good save. Glad you were not at speed on the freeway. Now you get to check them all!
Mark Jung
Bend, OR
MFI Werks.com
Author of "101 Projects"
Wayne 962's Avatar
Don't overtighten them though - or you can damage the aluminum housing. Also a good idea to use the RSR seals in the little grooves there to prevent oil leaks. The grooves were not meant for seals - they are meant to help the metal compress into the aluminum and seal. If your shaft was floating around here for a while, then it's probably damaged the housing a bit, and you may have difficulty getting them to tighten up again. Hopefully not, but definitely use the RSR rocker arm shaft seals - we have them in the catalog of course - the car needs 24 of them.
-Wayne
Old 02-11-2016, 11:46 AM
OMFG!
Don't worry J I know you'll have her up and purring like a kitten soon.
That last pic is crazy but I think you really got lucky.
Old 02-11-2016, 11:51 AM
SoCalSK8r's Avatar
Crazy stuff, I hope you get her up and running soon!
‘84 Carrera, heavily modded
Please follow me @chopped_up_fitness
Old 02-11-2016, 12:01 PM
scarceller's Avatar
Draco, Always something with these old cars. Very common issue, the walking rocker shaft!
Good news is they usually don't cause much damage if you shut the motor down as you did, wise choice! The only thing to be careful with is to be sure it did not damage the bore that the shaft slides into. Basically tighten it to spec and be sure you can't easily move it once tight.
The problem as Wayne pointed out is the bore on the RHS in the pic, because the shaft likely ran for miles slipped out of the LHS it can easily do damage to the RHS bore, the rocker puts significant pressure on the shaft when it opens the valve and the shaft was likely only held in place from that RHS, hope that makes sense.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 02-11-2016, 12:16 PM
Did the crazy rocker shaft nut/washer/bolt combo at least stay together, or did you have little parts flopping around in there as well?
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 02-11-2016, 12:24 PM
DRACO A5OG's Avatar
Luckily it stayed together,
Checking Cam lobe for damage now and next piston using my video probe
Thanks Wayne, I was about to order a new rocker ( inner busing is mared/damaged ) and shaft seals, will order the RSR seals instead, Where is it by the way?
'85 Carrera Targa
PCA/POC
Old 02-11-2016, 01:23 PM
Brew Master
cabmandone's Avatar
Who added the RSR seals? Mine is an 85 and didn't have them and I notice yours does.
Old 02-11-2016, 02:32 PM
Good catch, and I hope you are back on the road soon! On my '83, that bushing is separate from the rocker. You can probably take that rocker arm to your machinist/engine builder and get it re-bushed.
1983 SC
Blog
Old 02-11-2016, 02:36 PM
Functionista
manbridge 74's Avatar
My first 911 had this happen on the highway to the previous owner. He said it caused a loud bang. I bought it thinking the engine was trashed but I discovered the "walker" and put another rocker in it after a leak down test showed good numbers.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 02-11-2016, 04:42 PM
sugarwood's Avatar
Can someone circle the rocker shaft bolt (and explain what is actually wrong) for those of us who have never seen the inside of an engine?
1986 Bosch Icon Wipers coupe.
Old 02-11-2016, 04:56 PM
Chain fence eating turbo
One of the Achilles heels of the engine.
Hopefully the housing didn't suffer bore damage. Most of the time from my limited experience happening to me and reading here, they're usually ok.
Old 02-11-2016, 05:40 PM
The rocker shaft bolts are on both sides of the shaft, they have a hex head on each side, different sizes, I can't recall the sizes, perhaps 6 mm and 8 mm, when you tighten them they squeeze together expanding to seal tightly in the housing.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 02-11-2016, 06:18 PM
5mm and 8mm
Old 02-11-2016, 06:20 PM
DRACO A5OG's Avatar
Sugarwood, the bolt and nut are on side of the rocker shaft above.
8MM allen for the nut and 5MM allen for the bolt, they are shallow as poop so you have to make certain you are absolutely SQUARE to the two or you will fudge them up.
The two end are pretty easy to torque but the middle one that I blew up is going to be interesting. Will need to rig something up to torque that sucker.
So I looked at my CAM Lobe at #2, FUCH! I guess I am going to need a new one
or up to 964 Cams. Ah poop.
'85 Carrera Targa
PCA/POC
Old 02-11-2016, 06:21 PM
Banned
That little bit of wear/scuffing would not bother me for a second with a street engine. I would re-assemble with a new rocker arm and not give it a second thought.
Old 02-11-2016, 06:25 PM
DRACO A5OG's Avatar
But I need an excuse to up to 964 Cams. I have new Eibach valve springs just laying around too :-P
Yeah, but It will always bother me. Well, let me sleep on it. So now on the search for 964 cams.
'85 Carrera Targa
PCA/POC
Old 02-11-2016, 06:44 PM
Dial 911
A horse with no name's Avatar
Unhappy
Whoa!...Jim, so sorry to hear the bad news. As the Aussies say, "Bugga!" Actually it's even more than a "Big Bugga" I've never heard of any rockers coming unloose on any engine, but when reading the posts, it appears that they do on 911's. Not good.
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 02-11-2016, 06:51 PM
Tags
rocker assembly , rocker oil leak rsr seal , valve adjustment
