| Registered Join Date: Aug 2020
				123 distributor curve. Please look and comment!
			Hi Finally connected my usb 123 dizzy to the PC and the curve looks completely different and wrong compared to a normal 2.7 curve? Car is 1976 911s converted to megasquirt 1, MSD AL6, 123 distributor. Help!? Cheers   Last edited by SunburntLobster; 04-23-2021 at 09:59 AM.. | ||
|  04-23-2021, 09:57 AM |
| Registered |
			It looks like you are at 20 degrees at idle (1000 rpm) and then take a long time to get from 22 to 28 degrees.  Have you verified using a timing light? | ||
|  04-23-2021, 07:03 PM |
| Registered |
			It is wrong. Was it hard to start? At idle it should be closer to 10 degrees BTDC.
|  04-23-2021, 07:35 PM |
| Registered |   | ||
|  04-23-2021, 07:41 PM |
			Yup at cold it requires a light throttle to maintain idle at 900rpm. By time it warms up the idle is nearer 1200rpm. Also sounds flat and smells a bit! The dizzy cap and arm are burning out quickly. I plan to move curve 2 degrees at a time until I end up closer to stock graph and then request local dyno shop to fine tune | ||
|  04-23-2021, 09:49 PM |
| Registered Join Date: Jul 2013 Location: South East England
			All three devices are programmable for ignition curve.   I would be very careful, there could be curves lurking in the Megasquirt and the MSD box
|  04-23-2021, 10:10 PM |
| Registered | Quote:
				__________________ Rutager West 1977 911S Targa Chocolate Brown | ||
|  04-24-2021, 05:37 AM |
| Registered |
				dizzy
 SBL , said he changed the rotor SBL you should have a 1977 vw golf rotor in the 911
				__________________ Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains | ||
|  04-24-2021, 06:42 AM |
| Registered |
			SBL, like Jonny said you might have ghost curves lurking.  I think you should zero out the curves on the MSD and the MS and use the distributor. Set your curve as stock and then check with a timing light to verify.
|  04-25-2021, 05:13 PM |
