| Registered Join Date: Nov 2003 Location: Burke VA
				1974 MFI Carrera will not start.
			Hello Everyone,  I have a 1974 Row Carrera 2.7 MFI that will not start. I was driving it, parked it in the driveway I went out to restart it and nothing, it just cranks I have done all the things I know to do. I borrowed a friend's coil and CDI box which are known to be good and nothing. I checked the rotor and the cap and they seem to be ok.  I did get it to start once after cranking for a while. It ran for a few minutes and then died and now will not restart. Any thoughts?
				__________________ Jeff 1974 Euro Carrera 2.7 MFI 1966 Corvette 427 Coupe 2002 996 (Daily-Driver) | ||
|  04-27-2021, 10:59 AM |
| Registered |
			Check for spark then fuel.
|  04-27-2021, 11:57 AM |
| Registered |
			Sit in the car , hold the gas pedal to the floor , hand throttle to 3/4 up, crank the engine for 3-4 seconds , let your foot side slip off of the gas pedal, or lift your foot as fast as you can , while still cranking , it should start in the next 3 -4 seconds . You are trying to snap the throttle shut as fast as possible . Why this method ? You are trying to reset the rack inside the injection pump .Sometimes they get stuck , this process helps to reset this mixture rack. I hope this works for you, if not then to the next step Ian Only try this once , then to the next step. we don't want to flood the air box
				__________________ Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains Last edited by icarp; 04-27-2021 at 08:09 PM.. | ||
|  04-27-2021, 03:21 PM |
| Registered | Quote:
|  04-27-2021, 03:31 PM |
| Functionista Join Date: Jul 2011 Location: CO
			Points.  Almost always the points.  How did it idle before this?  Raggedy and unsteady?
				__________________ Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. | ||
|  04-27-2021, 11:26 PM |
| Registered |
			Sell to me as distressed merchandise.
				__________________ 63 356 2.1 Rally Coupe 75 911M 2.7 MFI 86 Sports Purpose Carrera "O4" 19 991.2 S | ||
|  04-28-2021, 07:31 AM |
			Thanks, everyone for your input. It was the points. I put a new set in this morning. It is running like a champ again.  I appreciate it.
|  04-28-2021, 10:39 AM |
They are still teaching.  I learned from Reinhold Noel who started at Porsche in 1966, wrote most of the service manual sections.  Classic fuel and ignition training in Ontario CA, 2017.
|  04-28-2021, 01:24 PM |
| cycling has-been Join Date: Sep 2004 Location: Jersey Shore
				 | Quote:
 Now make points adjustment part of your usual maintenance. As soon as the tach starts acting crazy, (jumping around at idle), get out your dwell meter and re-set the gap. Bill K
				__________________ 73 911T MFI, 76 912E, 77 Turbo Carrera | ||
|  04-29-2021, 09:06 AM |
| Registered Join Date: Mar 2004 Location: Higgs Field
			I'm glad you found the problem, but, just as an aside, I firmly believe we simply cannot source quality points anymore.  I gave up trying more than a decade ago.  Beyond old 911's, I own (and have owned) a broad variety of vintage cars and motorcycles that were originally fitted with points.  They have all been converted to some form of appropriate electronic triggering device.  I can see maybe sticking with points on a concours level restoration that does not get driven, but anything you would like to take out on the road and enjoy will be far more reliable and enjoyable if you eliminate the points.
				__________________ Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" | ||
|  04-29-2021, 07:52 PM |
			Sourcing quality Bosch points with the rubbing block made of the traditional Bakelite type material is difficult but not impossible.  Once adjusted after using good grease on the correct side of the block maintenance should be a yearly event.  Easy enough to carry a spare set in the glovebox.  I have nothing against the pointless conversions but guys do have issues with those as well.
|  04-29-2021, 08:08 PM |
