New Lug nuts for black Fuchs
For what ever it is worth, if you are thinking of purchasing new black lug nuts for your Fuchs get the aftermarket kind, not the OEM version. I purchase both to compare and the aftermarket nuts are far superior...harder surface and don't scuff as the OEM ones do.
Guy Chiattello 82SC Black Coupe |
where did you you buy?
1981 911SC Black metallic, no sunroof. Sold(damnit)2005 987Guards Red, Stuttgart build. Sold1978 911SC Bahama Blue, M491 look E class PCA race car.Sold with help from Pelican. Thanks! 2005 997 Black. Sold1988 930 Grand Prix White. Keeper. 2008 957 Basalt Black, Pneumatic suspension and PDCC. |
Is there a difference in cost? Can the aftermarket ones handle the stresses of a 911 as well as the OEM lug nuts, or better?
Professor M. Schiller Metro New York PCA America is successful not because of unions, but despite them. UNIONS DESTROY AMERICA www.CapitalistInstitute.org |
one of gods prototypes
i picked up a set of aluminum ones from our host.........my wheels haven't fallen off yet
Brought to you by Carl's Jr. |
Purchased from our host. Cost is about the same.
I've got a set from our host and they are much nicer than OEM
Harlan Chinn Pacific Northwest Region 1998 Carrera S ArcticSilverMetallic 1982 911SC PazificBlauMetallic |
are the aftermarket ones alluminum
Yes, The after market ones are alluminum.
Guy Chiattello 82SC Coupe |
Weird, what brand are Waynes nuts??
I am actually curious, but I couldn't resist... ![]()
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
They must be "generic nuts" The label on my box says "Aftermarket Alloy Lug Nut, Polished Each"
I have had trouble with the aftermarket lug nuts. They go on without a problem, but when I remove them, they loosen with a terrible squeak, like they bind with the rims. Yes the torque is correct, yes they are slightly copper pasted. The original (old) lugs used right after do not do that. Must be the alloy is not the same.
Kind of freaks me when I think about broken lug nuts stuck on the wheel. I solved my dilemma- back to steel lug nuts! Very "R Gruppe". GeorgeK |
apply some anti-seize on the threads
Irrationally exuberant
I have steel lug nuts. They are a bit rusty now. Anyone try POR-15 on steel nuts? I figureed I just paint the outside, not the threads or bearing surface.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Certified Pre-Owned
Personally, I'd throw a dab of anti-seize right on the mating surface of the nut (nut to wheel). I've seen them stick there (probably the squeak you're hearing) and then snap off right at the shoulder on the socket surface...
Just my 2 cents... -BG
'84 Carrera Coupe |
They HAVE anti-seize. It's as if the alloy of the lugs reacts with the alloy of the rims. Back to back testing shows this seems due to the alloy itself (?)
That is rather academic, as I go with steel lugs when the new engine is in. GeorgeK |
Thread Tools | |
Rate This Thread | |
