Trying to get speedo working - 911SC w/ 97 C2S Drivetrain
The speedometer in my ‘79 911SC w/ a 1997 C2S drivetrain (3.6L VR + 6-speed G50), hasn’t worked since purchasing the car last year. I speculate the speedo was never setup due to the car being a club race car for the past decade and a half. Any insights into how we might get the speedo working? Is the speedo driven by the trans or wheel speed sensors?
And the speedo was just rebuilt by North Hollywood. Thank you in advance. |
ROW '78 911 Targa
2 brown/red wires from speedo run through body harness to a location under the shift coupler cover plate in the tunnel, connect to the sender wires from the transmission.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 05-09-2021 at 10:20 AM.. |
7.0:1 > 11.3:1 > 7.0:1
As Bill says the 993 drove the speedo from the ABS system, these G50 transaxles do not have a provision for the speedo magnet ring inside the transaxle.
I used a 911 speedo in another brand of car and recreated the magnet ring around the perimeter of a cv joint, then added a bracket to hold the sensor. My magnet ring is just a strip of aluminum with the magnets epoxied in place and held onto the cv with a hose clamp. If you are handy you might be able to come up with something similar. ![]() |
Oh wow... thank you for the responses! Glad to hear I wasn’t going crazy when trying to figure out how to make this work. It appears there might be a reason the PO didn’t setup the speedo! Curious... anyone have experience with GPS speedometers? My concern is that I may go through all of the above, only to have the speedo off by miles due to the difference in wheel circumference over stock. GPS would potentially be an easy solve.
Curious if anyone has fit a GPS sender with their stock speedo...
https://www.egaugesplus.com/gps-speedometer-senders.html |
I would rather be driving
I too have done the "epoxy magnet to the CV joint and run a VR sensor" thing. Worked well.
GPS will ultimately be more accurate. The usual gauge houses can probably retrofit for you. Would have to check carefully to see if the linked GPS sender could replicate the same pulse signal as the stock magnetic pickup ring. I *think* that is 7 magnetic pulses per revolution.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
My first thought was to contact the gauge guys in CA and see if they can convert a stock speedo to GPS somehow, but i'm more curious to see pics of this conversion! 385 HP / 6 speeds in an SC? Thing must be a handfull!
Gary R. |
Thread Tools | |
Rate This Thread | |
