Agfours
Bucking, chugging, poor idle...solved.
The other day, I took ‘Dark Helmut’ for a spin and the car started to miss, then turned to a chug, bucking, and barely got her home…very poor idle and wouldn’t drive above 2000 RPM.
Checked fuel pump…ok. Replaced CHT sensor…ok. I have a Solid state DME, but swapped with a known good one…ok. Hmmm…fuel filter? This is what poured out of the filter…[see below] Recently refueled, but drove 50 or 75 miles before the issue started with vengeance. Wonder if this was lingering and finally got bad enough or if this was a bad tank of gas…leaning toward the latter. Thoughts? Replaced the filter and it ran better than ever, with much better throttle response and smooth idle. I am thinking I will just drive it and see if the clog comes back, and if so then drain the tank and replace the filter again (to see if this was built up over time, or if because of a recent fill up). Any advice in addition, or to the contrary? ![]() ![]() ![]()
Paul Present and accounted for: 1986 Carrera Coupe, 2021 Audi SQ8...Gone but not forgotten: 1987 Carrera Coupe, 1996 911 Carrera C4S, 1985 911 Carrera Cabriolet M491, 2011 Cayenne Turbo, 2001 Boxster S....Me: "What is your return policy?" FLAPS rep: "We really expect you to keep it..." |
I would be draining the tank, and more. That stuff came from somewhere and the tank is a good start place. The new filter will only cope with so much before repeat scenario.
Been thru similar recently with both my cars - replacing pumps, filters. Cleaning tank as best I can - back flushing fuel via return hose at tank, trying to clean swirl pot. When you have the drain bung off, feel inside - gritty?? Hint - easy way to empty tank first is siphon thru the fuel sender hole. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
there is a date on you fuel filter...how old is yours?
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Take the sender off and look in the tank.
Dont drop your flashlight in like i did! |
if your fuel filter is over 2 years --quite normal deposit, if u are changing different gas stations
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 05-16-2021 at 06:07 AM.. |
Agfours
Yes, I have had the car 2yrs, and the filter was at least one year older than that. It just seemed like a lot of sediment, and rusty in color.
I need to burn down the tank a bit as it is full, but I will pull the sending unit for a gander when I get to E…. |
I'm overdue for a fuel filter change then. Another thing on my list.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
I used to change the fuel filter on clients car every year.
Back in LA i did some testing.I went for 1/2 year to several different gas stations and it was almost like the above pic.But mind you in LA you drive a lot usually 20k a years no problem After i did another 1/2 year just one station and it was clean as a whistle.. Ivan
Older cars the fuel filter was a 15k maintenance item. Once a year.
I find it interesting that you can’t change the fuel filter on most new vehicles Sent from my iPhone using Tapatalk
Derrick |
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
Diss Member
Looks like you got a load of gas with a huge bunch of sediment in it. Were you in the area where they ran out of gas in the stations? When the storage tank is drained and they refill it, it can stir up all the sediment in the tank. If you show up soon after the tank is filled all that stirred up sediment can still be in suspension.
I would look at cleaning out the tank and "while you are there" replace all the rubber lines from the tank to the pump and from the pump to the fuel line in the body. Most cars have the original rubber and it is a ticking time bomb. And in general I make a point of not filling my cars from a station where they are filling the tanks and I only fill with Chevron (Techron really is that good of an injector cleaner) or Shell ("Nitrogen enriched" additive is good too) as a backup. I also try to use a gas station with a pretty high volume of business. At a really slow station the gas can sit there until the ethanol starts to settle out and they can get all sorts of problems with their tanks, lines and pumps. If you have a station that sells "pure gas" (no ethanol, not "oxygenated") that is good to stop corrosion in the car's fuel system and you can just add some Techron from time to time.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Agfours
This was an older, but heavily trafficked Texaco, and I'm not in the gas shortage area here in Austin. I use a bottle of Techron additive every few tanks as well.
Thread Tools | |
Rate This Thread | |
